Towing Mirrors Thoughts
Old Dec 28, 2021 | 01:30 PM
webs1981's Avatar
webs1981
Gang,
Yes, I’ve researched and have seen the previous threads on towing mirrors.
I have a 2020 F-150 Lariat and am looking to upgrade to the towing mirrors. My current stock mirrors (pictured) are POWER FOLDING, HEATED, FRONT TURN SIGNAL, LED SPOTLIGHTS (Puddle Lights) and BLIS (Blind Spot Information System).
Seems like there are some decent aftermarket towing mirror options out there such as Boost Auto/Tasca Parts, American Trucks, etc.
I’m thinking of purchasing the Ford tow mirrors directly through the Ford dealership and have them installed at the dealership. The biggest drawback for me on the towing mirrors from the dealer is that they are solid black mirrors. I was hoping they would have the chrome cover (I assume I can purchase the chrome cover as an aftermarket item).
But anyways, do you suggest purchasing the tow mirrors through the dealer and installed at the dealership OR purchase the aftermarket towing mirrors and install them myself? I’m just worried if I install the aftermarket mirrors myself that I won’t install them correctly, especially with the bells & whistles that are on my current, stock exterior mirrors.
Thoughts?
Old Dec 28, 2021 | 06:16 PM
Diesel_Brad's Avatar
Diesel_Brad
I would NEVER pay what the dealer wants for them, Nor would I PAY to have them install them. 100% plug and play on your truck. it takes less than 10 min to do both. Dealer will wack you at least $100
Old Jan 3, 2022 | 09:18 AM
99powerstrokedF250's Avatar
99powerstrokedF250
I have heard that there are some aftermarket ones that simply will not hold up over time. No personal experience, however.
That said, if they are wired properly for your options they should absolutely plug and play. So even if you buy the OEM mirrors for your truck (which, by the way, they should ALSO be able to order them with the chrome backing), there's not really a need to have the dealer install them unless you are concerned about warranty claims.
Old Jan 3, 2022 | 03:25 PM
Kingofwylietx's Avatar
Kingofwylietx
If it were me, I'd order the factory mirrors online and install them myself.
That answer is somewhere between your two listed options.
Old Jan 4, 2022 | 06:43 AM
bbender85's Avatar
bbender85
i put aftermarket 09-14 mirrors on my '07 and they worked and held up just fine for the 3 or 4 years i had them.
Old Jan 8, 2022 | 10:40 AM
GABAR's Avatar
GABAR
Before making your purchase at your dealership, make sure they’ll install them for you because many if not most Ford dealers will not install OEM parts that weren’t originally installed on your actual vehicle / VIN from the factory.
Old Jan 9, 2022 | 04:33 AM
ojai150's Avatar
ojai150
[QUOTE=webs1981;20215851]Gang,
i will share with you that when I got my 2017 lifted F150 SCEW , it had the optional towing mirrors that were power adjust, but not power fold.
this sucked because I parked in an apartment complex, and it didn’t feel safe to leave them out, so I had to manually fold them in and out ( both sides ) every time I got in or out .
I met a dealership “add on guy” by chance , and he replaced them with power fold puddle light mirrors for
$1k for both including labor ,
I have no idea where he got them for that price because I searched everywhere and couldn’t come close to that .
they have missed a lick and fold perfect every time for 3 years. The factory power fold mirrors would have cost me $3k just for the mirrors .
I am absolutely happy I had these put on , I use them several times every day when I park .
Old Jan 9, 2022 | 05:03 AM
NASSTY's Avatar
NASSTY
Boost Auto mirrors seen to be the best aftermarket option. I don't run them because I don't tow and can't stand the look of tow mirrors on half ton trucks. But there are a lot of people on the other F150 forum running Boost Auto tow mirrors.
Old Jan 9, 2022 | 09:20 AM
Diesel_Brad
Thats a new one to me. but I guess it would not hurt to ask
Old Jan 13, 2022 | 05:41 PM
jimmy-six's Avatar
jimmy-six
I use clamp on extensions that which slide and clamp with one thumb screw the stock ones on my 2018. they work great. I keep them by the door of my trailer.
Old Jan 14, 2022 | 10:16 AM
seventyseven250's Avatar
seventyseven250
I've done the clamp on kind, and they work okay. The factory tow mirrors are better, but the trade-off is they are larger, so you have more wind noise and width when you are not towing. Might have problems in urban areas, I've tapped mine on drive-throughs or parking garages.
Old Jan 18, 2022 | 01:18 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
I would never pay for them at a dealer. You will pay thousands. I got mine aftermarket at CarPart.com (to be clear I didn't pay for them, it was a sponsorship project.) They have held up great and don't vibrate or anything. My right one makes an extra noise when folding, but so does the one on my girlfriend's Explorer... I have no complaints. They've lasted 3 years. A direct swap is very easy. Even the upgrade swap I had to do on my xlt wasn't too bad.
Old Jan 19, 2022 | 12:06 PM
jimmy-six's Avatar
jimmy-six
I fold mine in every parking lot and in any drive thru. became a habit after i bought a Lariat with electric ones.
Old Jan 20, 2022 | 10:13 AM
ojai150's Avatar
ojai150
i agree , I had a guy put aftermarket power folding mirrors on my XLT and I fold them in each and every time I get out , I had a neighbor woman get in once and the window was down and she was going to push it out by hand , and I caught her in time , that would be bad ! I’ve never had to use them in the fully extended position, they really go out a long ways .
Old Jan 20, 2022 | 12:09 PM
JKBrad's Avatar
JKBrad
It doesn't hurt them to move them by hand. They are designed to break away. If moved by hand or by break away, just use the button to fold and unfold, the mechanism will catch and they will then function without issue.
