Mechanical fuel pump / is lobe up or down ?
Old Dec 27, 2021 | 09:14 PM
Scott in TX's Avatar
Scott in TX
https://youtu.be/KfTr4BLTjx4
Trying replace my pump, video is just after removal, looked like the lobe was down but not sure what it looks like when up
I bumped it over, did a test fit and had absolutely no tension or resistance, very loose,
If lobe was up would it feel like no tension or should there always be some sitting on the lobe?
Old Dec 27, 2021 | 10:26 PM
90Ford73's Avatar
90Ford73
Scott just tip the arm all the way down inside the block, slide it all the way in, and then tip it up and bolt it in. There might be resistance when you try to align it depending on where your lobe is. I would think that there would be less resistance if the lobe is up, as the arm is underneath not being compressed. Just make sure your arm is tipped all the way down and then slide it in so that your pump housing is against the block before tipping it up to align the bolt holes.
I’ve done two of these this way with no issue. I’ve never looked in to see the lobe. If your lift pump is the original, compare it to the new one. The new one should have a sharper “hook” at the end of it, this I think helps to ensure your under the lobe as I don’t think it would bolt up if you were on top.
Old Dec 29, 2021 | 09:33 AM
Scott in TX
Thanks for the reassurance,
there was absolutely no resistance, just slid straight in and bolted up without any tension, I did have to disconnect the hard line from the fuel filter to be able to attach it at the pump, I had more leverage to push the hard line to make it fit up top, I gave it a couple of bumps to see if there was any terrible sounds and then cranked it up and ran it for 30 seconds to look for any obvious leaks, none, so I'm letting it sit overnight for the permatex to dry before i give it a good run,
Old Dec 29, 2021 | 09:44 AM
90Ford73's Avatar
90Ford73
Good to hear! Your lobe must’ve been in the right spot then.
I remember way back either on this forum, or maybe even Dieselstop, reading about a guy who bought a 7.3 from the original owner. He had to tear into it for something, and when he pulled the oil pan off there were three pump arms and pins sitting in the bottom. Somebody got it wrong three times, finally got it in right, and this guy drove around for years not knowing they were there. Crazy lol.
Anyways, glad your up and running!
clydeford
Jan 14, 2015 03:38 PM
DAI532
27
Sep 24, 2009 08:34 PM
bigbadwolfe
Apr 1, 2008 08:27 PM
wla6518
Jul 30, 2006 12:14 PM
