Sponsored by: Real Truck
Hedlight Wiring
Old Dec 27, 2021 | 12:57 PM
David W McCarroll's Avatar
David W McCarroll
Hedlight Wiring
Hi guys, I recently changed the headlight assemblies on my 2001 F350 SD to a set of projector style headlights. I like them, but when I flip the dimmer switch to bright, the low beams go off. I know that is the way it is wired. I am thinking I would like to jumper the power wire to the low beam wire so that anytime the headlight switch is on, the low beams are on and when I switch to high beams, all 4 lights are on, not just the high beams. My question is what color of wires do I need to jumper in the steering column wiring to make this work? I don't have a wiring diagram available. All I need is a simple answer.
Thanks
Old Dec 27, 2021 | 06:11 PM
David W McCarroll
Never mind. I figured it out. It is the Red/Yellow and the Red/Black wires.
Old Dec 28, 2021 | 07:14 PM
Bugzilla46310's Avatar
Bugzilla46310
Not sure if that is actually legal to drive with both the low and high beams on at the same time.
Old Dec 28, 2021 | 07:27 PM
David W McCarroll
From 1958 through the 1990's cars were equipped with 4 headlights. That is the way they all worked. When you switched to high beam, all four lights were illuminated. My Father in Law's 1995 C1500 Chevy has 4 rectangular lights and all 4 are on when high beam is selected. TOday's F-series Fords have 4 headlight and all 4 are on whenever you have the lights turned on. So I am assuming it is legal.
AV3Fire
Feb 9, 2015 07:00 AM
sunbird79
Jun 4, 2012 10:44 PM
yellowtonka2
Large Truck
Oct 17, 2010 07:59 PM
imlowr2
Dec 9, 2004 05:44 PM
opjgeorge
Mar 26, 2003 03:36 PM
