High beams
Old Jun 4, 2012 | 09:04 PM
sunbird79's Avatar
sunbird79
High beams
I've setup my headlight wiring just like the diagram calls for on my 1950 F4. My question is should I have voltage on both high and the low beams when the high beams are on. If so would a bad dimmer switch cause only one circuit to be on at a time?
Old Jun 4, 2012 | 10:44 PM
ALBUQ F-1's Avatar
ALBUQ F-1
It's either wire is hot, not both. Separate filaments for high and low. The dimmer switch selects which one. NAPA sells an exact replacement dimmer switch, NAPA AUTO PARTS Dimmer Switch
Real common for them to not connect on one or the other, to hang up in between, etc. People aren't gentle with them!
bill11012
Feb 18, 2023 05:30 PM
muscletruck7379
General Automotive Discussion
Jul 9, 2012 06:19 PM
OKFords
1978 - 1996 Big Bronco
Jun 30, 2003 09:51 PM
metalcaster
Jan 27, 2003 07:48 PM
