Sponsored by: Innova
Rear cam install ??
Old Dec 27, 2021 | 10:11 AM
Katoom's Avatar
Katoom
Rear cam install ??
So first off I did do a search and didn't find much of anything that was helpful so now I'm hoping someone can provide some ideas that I can use for this.
So, this is going to be for my 2016 F250 SC, I just installed a new reciever unit with built in rear cam function and now I'm trying to figure how to route the 30' cable from the cab to the tailgate on my truck. Mainly I'm curious what people have done to route the cable out of the cab, amd I going to need to drill a hole or is there already a hole somewhere in the floor that I can use?
Old Dec 27, 2021 | 04:29 PM
madsonp's Avatar
madsonp
On my 2012 if I recall correctly I routed my wiring down along the drivers side rocker panel along an existing harness inside the cab, then under the carpet around the back seat there was a plug (grommet) in the floor I pulled out and routed the wires outside the truck there, then I ran them in some wire loom along an existing harness that ran along the frame to the back of the truck that I zip tied it to.
Old Dec 28, 2021 | 02:10 PM
Katoom's Avatar
Katoom
Ok... guess I'm going to be pulling the seats out so I can get a clean run under the carpet.. That will give me a good chance to give the truck a good cleaning in the interior anyhow..
Stevem4134
May 20, 2017 07:42 AM
kengarchow
Sep 5, 2014 10:03 PM
debestuss
Mar 16, 2005 03:51 PM
fordeverpower
Jul 19, 2004 05:50 PM
