Question: Replacing Headlight Bulbs
Old Dec 25, 2021 | 10:52 AM
acadianbob's Avatar
acadianbob
Bought some Sylvania Ultras. I've watched some videos on bulb replacement. They have you removing the grille and the whole headlight assembly. Is this the route that most of you have taken? If not, how have you accomplished the job? The truck is a 2021 with a 7.3. Looks like the air cleaner assembly has to be at least partially disassembled.
Also, does the plug just pull off of the bulb or is there a release clip?
Thanks for any guidance. I'm not exactly a mechanic and I'm a bit cautious . . . . don't want to break anything.
Old Dec 25, 2021 | 10:58 AM
CR250Bronco's Avatar
CR250Bronco
I too am interested. Can anyone post any videos of this? And share how to do it?
Old Dec 25, 2021 | 11:42 AM
GAZZILLA's Avatar
GAZZILLA
No, just remove the air filter box (Passenger Side) and the filler neck for the windshield washer reservoir (Drivers Side).
Old Dec 25, 2021 | 11:56 AM
Jake2544's Avatar
Jake2544
Wish I would of known that, I just sent back my F150 bulb order back for a refund. Took the whole grill out, broke some tabs doing so and still couldn’t get the headlights out. The bumper would of had to be dropped down to get them out.
Old Dec 25, 2021 | 12:01 PM
ATC_F350's Avatar
ATC_F350
This is the way to do it, and the bulbs twist and pull out. You will get a scratch or two on your arm, and I had to get pliers on the bottom driver side to get it to turn.
Old Dec 25, 2021 | 12:21 PM
Poncho450's Avatar
Poncho450
This. ⬆︎
I've changed bulbs many times in the 4 trucks of this body style that I've owned. Removing the grille is a lot of unnecessary work. For dual battery 7.3 truck you may want to remove the driver side battery, but I didn't.
One more pro tip: make sure the red gasket comes out with the bulb. If it sticks to the headlight housing, you'll never get a new bulb in there with a double gasket.
Old Dec 25, 2021 | 12:31 PM
2020STX250's Avatar
2020STX250
Air box for sure has to come out. Filler neck on the water bottle is 50/50. I was able to change out the lamps in mine with just unplugging the water bottle sensor wire and worming my arm down there, but I could see where taking out the filler neck would help.
When you go to unplug the lights push the connector in a bit then hit the release tab. The release will come off easier when you go to pull it off.
Old Dec 25, 2021 | 03:17 PM
acadianbob's Avatar
acadianbob
OK. I got the air intake separated, filter out, snout off, but the base of the intake doesn't seem to want to come out. Looks like it should just lift off but it seems "connected" down where there appears to be a drain hole. Afraid to pull too hard and break something.
Old Dec 25, 2021 | 05:59 PM
GAZZILLA's Avatar
GAZZILLA
There’s a couple of grommets that you have to pull it out of. Pull and wiggle it up and out.
Old Dec 25, 2021 | 07:52 PM
CR250Bronco
its people like you who make forums worthwhile! Thank you
Old Dec 25, 2021 | 09:07 PM
KU4OJ's Avatar
KU4OJ
Pictures of this whole operation would be really great.
Just sayin'.
Old Dec 26, 2021 | 07:56 AM
Poncho450's Avatar
Poncho450
Those rubber grommets are very secure and it takes a stout pull. Loosen the big hose clamp and undo the big rubber bellows from the air cleaner end also. DO NOT grab through the snorkel hole and pull. Very little material there and it'll crack.
Old Dec 26, 2021 | 07:57 AM
Poncho450's Avatar
Poncho450
Just sayin'.
Breather removal, this is where I learned.
Old Dec 26, 2021 | 09:50 AM
acadianbob's Avatar
acadianbob
Thank you so much!! That helped a lot.
Old Dec 26, 2021 | 11:50 AM
scraprat's Avatar
scraprat
Top Answer: 5
@acadianbob so how much brighter are those babies. Good light going down range? Did you readjust the lights?
