Sponsored by: Real Truck
Dually brake help
Old Dec 24, 2021 | 09:02 AM
Michael338's Avatar
Michael338
Dually brake help
Hi all,
I have a 2009 f350 dually and have some questions about doing the rear brakes.
What size bearing lock nut socket will I need?
What is the torque for the lock nut?
Due I need to replace the axle shaft seal?
Is there a hub gasket or any other gasket/seal that needs to be replaced?
Any other surprises I should now about?
I've done brakes before, just never on rear duallys.
Thanks in advance!
Old Dec 25, 2021 | 08:25 AM
Djosbun's Avatar
Djosbun
OTC 7269 is the socket for the real axle nut used on the dually. There's an o-ring for the axle face you should replace. I don't recall the axle nut torque but you'll find it if you use the search function. Brake job itself is easy. Just don't ignore the caliper pins since many seem to do so.
-- Dave
Old Dec 25, 2021 | 09:11 AM
nydiver's Avatar
nydiver
I could be wrong, but aren't the rear rotors independent of the rear hub? i.e. you don't have to remove the hub to remove the rotor for a brake change unless you also want to change the hub bearings too. At least I know all the SD's I've owned are that way.
jawroper
Jun 2, 2015 08:35 PM
mgerdau
Apr 15, 2013 08:49 AM
struggler
Jan 20, 2008 01:03 AM
bfbchief
Mar 24, 2006 06:50 PM
sinmanOR1955
Jan 10, 2005 03:39 PM
