So, the dealer got the recall done on my new 2021 and I picked it up this afternoon. Since they only supply two keys I normally buy an additional key fob and program it in case one gets damaged or lost. I did it with every Ford I've owned since 2000.
So I go to the owners manual and it states that I can purchase a new key from the dealer and they can program it. I would rather not if I don't have to. I saw a couple of sites on the internet that claims a new remote can be programmed by the owner.
So, has anyone programmed an additional remote to work with your trucks? If so what was the process? Any help appreciated.
Yes, I know it’s keyless but a fob without a physical key attached to it is technically still considered a key and the same info that I mentioned previously about programming applies to both.
Good luck to you on programming a third key “fob”.
Everything I see is I can program a couple of MYKEYS. There's nothing about programming admin keys. So, my plan is to purchase a couple of spare fobs, program them as MYKEYS with no restrictions, and store the admin keys away. That should get me around paying the dealer crazy fees to do it for me.
I saved a ton of money and it was an OEM key Fob. I looked up the programming instructions and did it myself. It took a couple of tries but I got it. I watched a online video that showed me the steps to do it.
