MAX PAYLOAD QUESTIONS
Old Dec 24, 2021 | 11:23 AM
RV_Tech's Avatar
RV_Tech
On the gooseneck prep, if all you want is the in-bed plug, those are super easy to add at minimal cost.
Steve
Old Dec 24, 2021 | 11:51 AM
RFT2112's Avatar
RFT2112
Steve
Agree. I did it on my current truck but ordered gooseneck prep on new to have that option in future. Which is also doable at a later time.
Old Dec 24, 2021 | 01:36 PM
WNDR RVA's Avatar
WNDR RVA
THANKS ALOT GRINDMONKEY!!
EVERYTHING IS BEGINNING TO MAKE SENSE. I LIKE THE IDEA OF SPEAKING TO THE FLEET MANAGER IN HOPE THAT THEIR SOFTWARE MAY PROVIDE SOME GUIDANCE.
Old Dec 24, 2021 | 01:55 PM
WNDR RVA's Avatar
WNDR RVA
WOW, THANKS FOR ALL OF THE GREAT EXPERIENCE FROM EVERYONE. DANG! IF I HAD TO TAKE A SURVEY OF THE RIGS THAT MOST OF YOU POSTED, AND ESPECIALLY THE COMMENTS ABOUT THE BENEFITS OF A F450 DUALLY (STRONGER BRAKES, AXLES, ETC); IT SEEMS THAT I SHOULD PURCHASE A F450 DUALLY AS IT WILL PROVIDE ME MORE CAMPER OPTIONS/CHOICES.
Old Dec 24, 2021 | 02:17 PM
RFT2112's Avatar
RFT2112
Everything I’ve read says an F450’s payload isn’t as much as a DRW F350. Correct me if I’m wrong. Otherwise I would of went with a 450.
Old Dec 24, 2021 | 03:17 PM
crewzer's Avatar
crewzer
That’s technically correct, as both the F-350 DRW and the F-450 are rated for 14K lbs. GVWR, but the F-460 is ~450 lbs. heavier (assuming 6.7 Diesel engine in both), so the payload is correspondingly lower.
But there are are gives and takes. Both come with long beds only and in either 4x2 or 4x4. The F-350 DRW is available with gas and Diesel engines, and with regular-, super-, or crew cabs. The F-450 is only available with the 6.7 Diesel, and only with regular- or crew cabs.
Officially, the F-350 DRW 7.3 4x4 has an ~1200 lbs. payload advantage over the F-450 6.7 4x4.
The F-450 is nonetheless a very popular choice, as it comes with larger wheels and tires, bigger brakes, and a tighter turning circle.
HTH,
Jim / crewzer
Old Dec 25, 2021 | 10:29 AM
WNDR RVA's Avatar
WNDR RVA
Merry Christmas and THANKS!!!
Old Dec 27, 2021 | 08:19 AM
beachcamperf250's Avatar
beachcamperf250
That is all on paper. Check out a 450 vs a 350 on the sales lot if you can find one and you will see clearly the 450 is a superior truck for hauling a heavier TC. The only downside is you can't get the 7.3 gas in the pickup version of the 450, would have to buy a commercial version and put a flatbed or service bed on.
Old Jan 4, 2022 | 08:15 AM
17 Oaks's Avatar
17 Oaks
Originally Posted by crewzer
WNDR,
In a perfect world, I would recommend you first decide on a camper (or range of campers) and perhaps your next camper as well. Then, knowing your requirement, decide on a truck and its trim, features and options.
The moonroof is a heavy option (64 lbs. IIRC). I suggest you research this forum for discussions about its reliability and leaks.
The dual battery configuration is another heavy option (~60 lbs. IIRC). It’s probably helpful when using the truck for plowing snow or winching, but I don’t see it being at all helpful for carrying a TC.
The 7.3’s standard alternator is rated at 240 A, which I so far think is plenty.
If you’re going to carry a TC, the camper package is an essential option IMHO, as the rear stabilizer bar will add some measure of side-to-side (roll) stability. After market models are also available.
The optional camper package does not increase payload. If you decide you need more payload, configuration options include the SuperCab long bed and the crewcab long bed.
The ability to boondock for two- to four days will be affected by your camping style, your camper batteries, and perhaps a solar array on the TC roof. We can discuss that topic separately in more detail.
There are several people on this site that know a fair amount about these trucks and about truck campers. I believe we’ll all offer useful perspectives.
HTH,
Jim / crewzer
Jim if folks only took that advice!
Payload: Pay ($, $$, $$$) Load. Its an OLD term that stems from the days when folks who drove truck were making money off that truck. So the question became Mr. Salesman how much load can I carry that I can make money off the truck. This resulted in the monikers of Half Ton, ¾ Ton, 1 Ton and then further refined to a specific amount in lbs and ended up on a door jam sticker. So what is that number? Can I find it in the Federal or State DoT Rules and Regs, not specifically but what you can find are Classes of truck which is based upon gross weight.
Lets look at class 3. If your truck is a Class 3 and specifically 14,000 lbs then this number will be the base number on which to calculate the Payload. Your truck will come with a rating, if its over 10,001 lbs its a Class 3 and that number will be used a the prime number and arrive at your payload...That said its not a good way to do it but its simple. It hurts the F 450 because the F 450 is a heavier truck due to its components in the driveline. The F 450 is based upon F 550 components with the exception of the rear Spring Pac which is a F 350 DRW and its this that Ford relies upon to stay in the Class 3 because when you make the jump to 14,001 lbs you go into Class 4 which is the Federal Commercial classification. This can take you into CDL requirements, Federal Excise Taxes, more costly plates and registeration and issues with obtaining insurance.
2. Medium truck classes
CLASS
WEIGHT LIMIT
TRUCK EXAMPLES
Class 3
10,001–14,000 pounds (4,536–6,350 kg)
Chevrolet Silverado/GMC Sierra 3500;
Ford F-350;
Ram 3500;
Isuzu NPR.
Class 4
14,001–16,000 pounds (6,351–7,257 kg)
Chevrolet Silverado 4500HD/International CV;
Ford F-450 (chassis cab and pickup);
Ram 4500;
Isuzu NPR-HD.
https://batrkr.com/truck-classification-weight/
BEAR in mind there are 51 sets of DoT Rules and Regs: 50 at the state level and 1 for the Federal, they are a true witches brew.
My recommendation to anyone who wants to carry a TC of > 3000 lbs wet the truck should have a Anti Sway bar in the rear, HD shock and a suspension system that does not sag or can be modified ORGANICALLY with component(s) (such as Upper StableLoads or revised overload springs) and be a DRW. Your travel weight will typically add somewhere between 600 up to 1000+ lbs in gear, food, supplies and add ons.
MPM1979
29
Dec 28, 2021 06:36 PM
Rasalas
Aug 31, 2017 01:45 AM
CGA
Oct 2, 2016 05:06 PM
Kilted in the OC
2004 - 2008 F150
Nov 16, 2008 10:28 PM
pilot10
25
Aug 6, 2002 10:33 AM
