Sponsored by: Real Truck
Secondary Cooling System Temps?
Old Dec 20, 2021 | 12:25 PM
gustrider4's Avatar
gustrider4
Has anyone been able to read their Secondary Cooling system water temps? Or even adding a sensor and integrating into a Livewire TS? 2014 6.7
Old Dec 20, 2021 | 05:38 PM
Just Strokin's Avatar
Just Strokin
There is probably a PID for the secondary cooling system temps. I am sure the PCM/ECU would shut down the truck or put it in limp node if the temp was too high. If you had a list of the P-codes, you might be able to trace it further is you knew what P-code was for the secondary cooling system
I do not remember seeing any place in the 6.7 about the temp or how to read it. You might ask this question in the 6.7 Forum.
6.7L Power Stroke Diesel - Ford Truck Enthusiasts Forums
