09 E150 4.6L Stalling.
I’m looking for help diagnosing my work van. It recently started stalling at low idle when coming to a stop or changing gears.
I have read some threads on here and other locations and am a bit overwhelmed by how many things seem to be able to cause this problem. I am hoping to narrow it down if possible and any help will be greatly appreciated!
here is what I know.
Dash light that we’re on previous to the stalling issue.
- ABS
- Traction Control
Codes that it is showing while running.
- C1096-E0 CMDTCs pump motor circuit open
- C1096 ODDTCs pump motor circuit open
Recently I was driving and it went into limp mode. Unfortunately the check engine light is still not on and showing no other codes. When I restarted the vehicle limp mode was gone.
that’s what I know. Any ideas? Thanks!
You'd be more betterer served if you post in 1968-2013 Full Size Vans ««« -click-
