Boss 300
Old Dec 18, 2021 | 07:11 PM
japar's Avatar
japar
Boss 300
https://www.facebook.com/YourEngineGuy/videos/364562958774518
Old Jan 15, 2022 | 12:47 PM
nickfjields's Avatar
nickfjields
4wd Low
Totally crazy how the head was fabricated. I would have expected maybe just one weld to connect two cut down heads but welding together a separate section for each cylinder!? Crazy engineering!
Old Jan 15, 2022 | 01:30 PM
The Frenchtown Flyer's Avatar
The bore spacing for a 300 six is 4.480"
The bore spacing for a Cleveland and Boss V8 is 4.380".
The only way a Cleveland head will match up to a 300 six is to machine six separate chambers and space them at 4.480" accordingly.
Often times the head bolts are increased from 7/16" to 1/2" for increased clamping force on the head gasket.
Old Jan 15, 2022 | 01:39 PM
nickfjields
4wd Low
Thanks for the explanation. Coming from small turbocharged engines I'm familiar with porting heads and minor mechanical work, so much with those motors is about the computer tuning. I am constantly impressed with the ingenuity of the earlier generation of hot rodders and racers when there was no such thing as a "bolt-on" modification, everything seems to involve the vertical mill and the welding rig and some actual engineering know how. I love this kind of stuff where some smart guys basically re-engineer a motor using parts from every manufacturer!
Old Jan 15, 2022 | 02:15 PM
85e150's Avatar
85e150
I thought they did 3 sections on the "close enough" principle.
Most of the links I found are gone. There are some pics.
But there is also an alternative:
https://engineswapdepot.com/?p=4014
Old Jan 15, 2022 | 04:22 PM
AbandonedBronco's Avatar
AbandonedBronco
I recall seeing some that were just two sections.
The #2 and #5 cylinders were centered, and then their left and right companions were just a hair off.
Old Jan 16, 2022 | 08:16 AM
In the beginning there were two.
Then some did three.
The most astute realized that six were needed for perfect alignment of all six holes.
TheDudeAbides
Jul 29, 2022 01:26 PM
GammaDriver
Aug 12, 2002 11:10 PM
truckzilla
Aug 17, 2001 12:06 AM
TallPaul
Jan 11, 2001 09:03 PM
