Sponsored by: Auxito
extended crank time
Old Dec 17, 2021 | 07:23 PM
96f150's Avatar
96f150
extended crank time
.....01 5.4L with 212k.....Ive got a longer than normal crank time which only does it from cold start. Doesnt do it when you shut it off and restart 10 min later. Used Torque app....no codes....I DO have:
TID $01 CID$11
TID $01 CID $21
TID $03 CID$01
TID$03 CID $02
no misfires at all
I dont know much about how to read the TID's
any advice on where to start?
Thanks
Old Dec 17, 2021 | 09:48 PM
Johnny Paycheck's Avatar
Johnny Paycheck
I’d definitely hit the schrader valve with a fuel pressure check. I’m thinking the pressure regulator is bleeding off over some time, but you’d find that with said test.
Old Dec 18, 2021 | 07:26 AM
projectSHO89's Avatar
projectSHO89
Yeah, it's likely a pressure leakdown problem. Torque (or a scan tool) probably isn't going to help you with that type of issue.
Quick check is, after an extended shutdown that should trigger the symptom, to cycle the ignition from OFF to RUN (not START), wait 3 seconds, then switch it back to OFF. Repeat several times then hit it to the START position. If the engine fires up immediately, that usually confirms the leakdown thesis.
Old Dec 18, 2021 | 08:23 PM
96f150's Avatar
96f150
Thanks all for the quick info...Ill give it a shot
thanks
Rich
Ed Letterman
Feb 18, 2020 11:50 PM
Lockholder
17
Mar 1, 2019 09:19 AM
kylant
Apr 23, 2017 03:48 PM
Macrosill
May 17, 2015 04:09 PM
94WhiteF250
Feb 29, 2012 08:00 PM
