351 power ??????
Old Nov 4, 2003 | 04:44 PM
powerless's Avatar
powerless
351 power ??????&weight???
can you run 400 to 450lbs and matching HP through the broad range of the power band. without having a tricked out motor. And yet still having a 351 windsor that will be tough and last. any good, solid build ups would be helpful info. thanks. oh and would anyone happen to KNOW the actual weight..thanks......
Old Nov 5, 2003 | 01:10 PM
jwtaylor's Avatar
jwtaylor
Define tricked out.
Old Nov 5, 2003 | 04:18 PM
powerless's Avatar
powerless
well i'm wanting something for a daily driver so i need an engine that can run with havig to be constantly looked at and tuned and checked for this and that.mmmm???? you know no huge carbs, short excessively loud exhaust. i perfer the sleeper look as apposed to the show my a-- look.bascily i want the aftermarket parts to be installed to lose weight more than anything.
Old Nov 5, 2003 | 06:17 PM
jwtaylor's Avatar
jwtaylor
You could build a fairly stout motor for a daily driver, you may find that 400-450hp is a lot for a daily driver. A stroker motor with good aftermarket or recondtioned/ ported heads and a good cam should get you around 400 reliable hp just depends on who does the machine work and assembly. How much you wanna spend?
