battery change and settings?
Old Dec 14, 2021 | 03:19 PM
jims94vmx's Avatar
jims94vmx
Just got an Odyssey extreme for 280.
When swapping out will the truck still remember the miles towed etc?
I don't have a bms so should be easy swap. I read about letting it sit fir around 8 hours? Any advice?
Thanks
Old Dec 14, 2021 | 07:21 PM
senix's Avatar
senix
Just swap and go. It should retain the info. Radio stations probably not.
Dual batteries would if you changed them one at a time.
Old Dec 14, 2021 | 07:32 PM
GMB Racing's Avatar
GMB Racing
IF you have a jump pac just connect it before removing the old battery and all settings will be retained
Old Dec 15, 2021 | 04:04 AM
GABAR's Avatar
GABAR
The vehicle will be fine because it’s only going to be disconnected for a minute or so when swapping batteries.
Yes, just let the vehicle sit for around 8 hours which works out just fine when you hit the bed 🛌.
JDJR59
Jan 22, 2023 08:20 AM
wdhunt698
Nov 15, 2021 05:50 PM
Big-Red-Lariat
2015 - 2020 F150
15
Dec 14, 2018 12:51 PM
ukmat71
Jun 12, 2007 02:26 PM
Dutch123
1978 - 1996 Big Bronco
Aug 3, 2004 09:26 AM
