Displacement Question
Old Dec 12, 2021 | 06:38 PM
MasterX's Avatar
MasterX
MUST GO FASTER!!!!
This is more less inconsequencial, but i was telling someone i ran into at the auto parts store about my engine and told them about the rebuld, showed them pictures, and the such
When i mentioned it was bored 030 over, they asked, oh, what is the new displacement, and well, its a good question....
using ford numbers i found for the stock engine i came up with the following, any of you know if its accurate?
I used this calculator here: https://performancetrends.com/Calcul...splacement.php
Stock Bore: 3.552
Stock Stroke: 4.165
Cylinders: 10
Comes up at 412.72 Cubic inches for a stock motor which is 2 and change off Fords spec of 415 CI, but then on another site someone mentioned the extra 2.28 cubes come because of the dished pistons which makes sense to me.
So using the same math i added the 030 to the bore number and did the following math on the same calculator
Bore: 3.582
Stroke: 4.165
Cylinders: 10
And according to this calculator my new displacement is 419.72, but then add in the 2.28 for the dished pistons, so a new total of 422 cubic inches?
Is this correct?
Old Dec 12, 2021 | 07:13 PM
85e150's Avatar
85e150
No. The dish or pop up or flat of the piston has nothing to do with displacement. It's volume of a cylinder x the number of cylinders. Straight geometry. "Advertised " displacement might be rounded, based on an inaccurate conversion from metric to inches or simply made up to sound better. 427s were actually 425s, and there are others.
Old Dec 12, 2021 | 07:20 PM
MasterX's Avatar
MasterX
MUST GO FASTER!!!!
ok, so asside from the dish, is the math above correct or incorrect?
Old Dec 12, 2021 | 07:24 PM
callforfire's Avatar
callforfire
This kind of imaginative "rounding up" happens everywhere. The same way .44 magnum mics out at .429. Honesty would mean calling it the .43 magnum but who would buy that?
it's even worse in motorcycles where 1000cc's is really 963 because reasons.
Old Dec 12, 2021 | 07:42 PM
Dweber85rc's Avatar
Dweber85rc
Yeah my 450 honda 4wheeler has 433cc displacement if I remember right. The manufacturers always fudge a bit.
Old Dec 12, 2021 | 08:58 PM
WE3ZS's Avatar
WE3ZS
And my 1 liter Geo Metro 3 cylinder is actually only 993CCs, but it pulls like a full liter!
Old Dec 12, 2021 | 09:56 PM
MasterX's Avatar
MasterX
MUST GO FASTER!!!!
since no one knows, until a better answer comes along, im just going to split the difference and say its 420 CI
Old Dec 12, 2021 | 10:14 PM
85e150's Avatar
85e150
The caluclator above agrees with other calculators and at .030 over you end up with 419.72. 420 is close enough.
https://www.omnicalculator.com/math/cylinder-volume
Old Dec 12, 2021 | 10:37 PM
MasterX's Avatar
MasterX
MUST GO FASTER!!!!
So right on the edge of 6.9 liters, at 6.8779785 give or take a few microns
mdlave
Jul 1, 2013 10:27 PM
powerstroker27
Feb 18, 2009 03:47 PM
rcav8or
Feb 15, 2008 11:24 PM
nastruk95
Nov 22, 2004 06:07 PM
Nathan
Jan 18, 2001 11:34 PM
