Sponsored by: Real Truck
Key fob range gone
Old Dec 11, 2021 | 11:16 PM
graphicjunkie's Avatar
graphicjunkie
Key fob range gone
All of the sudden, my two brand new key fobs won't activate the door locks (lock/unlock) unless you are standing right next to the DRIVER's door, and in the perfect spot. It's like the antenna on the truck quit working. Find the perfect spot and angle..and bam.
I've been searching quite a bit on this, and everything is always about the actuators not functioning because of the relays in the GEM/VSM module. Mine work just fine. They are very strong and crisp on both the lock and unlock functionality when you hit the door button. So I don't believe the relays are the issue per all the research I've found.
Is the "receiver antenna" for the keyless entry also on the GEM/VSM module? Or is there another module responsible for that?
I've been on google, youtube, and searched through a crazy number of threads on here, and again...it's always about the relays failing. I did read that Ford had stopped building the modules, due to age. Pretty shameful since the trucks are still so popular. But expected at the same time.
Old Dec 12, 2021 | 12:05 AM
Jimmy's Pilot Service's Avatar
Veteran: Navy
I would say try new batteries before doing anything. Likely you new fobs were sitting for a bit and batteries are not fresh.
Old Dec 12, 2021 | 01:00 AM
graphicjunkie
I will give that a shot. They didn't come with batteries, so I had to buy them. Not to say that I couldn't have gotten some old batteries off the shelf as well.
Thx.
Old Dec 12, 2021 | 04:02 PM
graphicjunkie
Well, tested the batteries in both fobs. Both showed +3v....
But knowing batteries can be batteries, replaced them... No difference.
Old Dec 13, 2021 | 01:15 PM
Shovelheadrob's Avatar
Shovelheadrob
I don't know what year your truck is but..........my 2000 started doing this, probably a year or so back, I replaced the batteries, reprogrammed the fobs etc. Sometimes the fob would work normally for a few weeks but eventually they stopped working altogether. I ended up having an aftermarket remote locking module fitted.
scott91370
2020+ Explorer
Mar 24, 2021 03:14 PM
MasterX
Oct 21, 2020 10:58 PM
CarolinaCanes
Oct 13, 2020 10:34 PM
CountrygirlF350
Electrical Systems/Wiring
Oct 26, 2018 07:00 PM
1handyhubby
Jun 17, 2016 03:46 PM
