Identify Transmission
Old Dec 11, 2021 | 10:15 PM
uuuhCharlie's Avatar
uuuhCharlie
I have a 1989 f150 4x4 with a 302 swapped in and a manual 4 speed with overdrive also swapped in and I'm having trouble identifying the transmission due to it not being the original transmission. I'm not sure where to look to find what I have. Any help?
Old Dec 11, 2021 | 11:51 PM
85e150's Avatar
85e150
Is your transmission a 4 speed OD or a 5 speed?
4 speed OD can be in one of 3 configurations, all based on the performance "top loader" 4 speed from the '60s.
Iron case, side mounted linkage, should have "RUG" on the case, compared here to the original performan trans:
Toploader Imposters
SROD, the Single Rail OverDrive, also seen in Mustangs and other cars with slightly different ratios. Aluminum case:
https://cimg7.ibsrv.net/gimg/www.for...242f9b2498.jpg
Top Shift version. "RTS TS OD"
https://cimg1.ibsrv.net/gimg/www.for...4fc7d51a92.jpg
Post 7 has the TS OD illustration and some application info:
https://www.ford-trucks.com/forums/1...nsmission.html
IF IT'S A 5 SPEED
Mazda "M5OD" found in F150s behind 300 & 302, and a few 351Ws:
http://www.smartpartsauto.com/images...or-sale_03.jpg
ZF 5er, found in F250 and up behind many engines:
https://www.ford-trucks.com/forums/a...1&d=1343236461
Mazda: Horizonta;/vertical ribs
ZF: Diagonal ribs.
Old Dec 13, 2021 | 04:17 PM
uuuhCharlie
it is 5 speed with the 5th gear being overdrive
Old Dec 13, 2021 | 04:36 PM
85e150's Avatar
85e150
Mazda M5OD.
That was a standard offering in '89.
Old Dec 13, 2021 | 09:35 PM
uuuhCharlie
Originally Posted by 85e150
Mazda M5OD.
In my Chilton manual it says to give it Mercan atf.
that doesn’t sound right to me would you happen to know if that’s correct?
Old Dec 13, 2021 | 09:49 PM
AuroraGirl's Avatar
AuroraGirl
Mercon V ATF probably for less energy losses. SM465 could have had gear lube or ATF too.
good question tho
Old Dec 13, 2021 | 10:05 PM
sevensecondsuv's Avatar
sevensecondsuv
ATF is the correct fluid for an M5OD. Anything thicker will make it impossible to shift and might even cause damage.
Old Dec 13, 2021 | 11:23 PM
85e150's Avatar
85e150
Check the 3 plugs on the top cover. They are known to dry out and leak.
If you have shifting issues, the top cover does come off and the shift forks can be replaced if need be.
StPat
Jan 30, 2019 06:22 PM
ngafreeride
Aug 10, 2008 12:33 PM
muscletruck7379
Sep 25, 2003 12:30 PM
Scott_in_Canada
Jul 3, 2003 04:39 PM
Ford78_302
Feb 23, 2000 08:30 PM
