Power mirrors issue
Old Dec 10, 2021 | 02:27 PM
jimzpsd's Avatar
jimzpsd
Power mirrors issue
While moving the power mirror around to adjust as needed, both mirrors will move the glass but only a small amount. I can hear the electric motor moving but the glass does not, it will move with the slight push of the finger to assist it. Happens on both sides. Been working normal for the last four years. Any ideas?
Old Dec 10, 2021 | 06:37 PM
Crotchety Ford truck only's Avatar
You'd think that with both mirrors exhibiting the same weakness it would be the circuit that feeds or grounds both position switches and mirrors. I wonder if the defrost works off the same circuit, and how that is. Also if there is a voltage drop somewhere that is delivering but not enough.
Old Dec 10, 2021 | 07:00 PM
jimzpsd's Avatar
jimzpsd
It sounds as if something is disengaging, some times they work a couple of times , full up, full down, etc. but then they don't work yet you can hear the motor driving. Wife thought maybe its a cold temperature issue, (mid thirties F).....but they always good before, even below zero.
Old Dec 10, 2021 | 07:11 PM
jimzpsd's Avatar
jimzpsd
I found this...........it has to be the fix, and its free (if I don't break a lens)
Old Dec 10, 2021 | 07:58 PM
https://www.youtube.com/watch?v=J4tZN3vpTMQ
That would be nice huh............... Odd they both worked good, then both had a problem at the same time that was an individual problem with each. Let us know how the fix turns out.
Old Dec 10, 2021 | 09:51 PM
jimzpsd's Avatar
jimzpsd
Yup, same happened to the guy in the video...both mirrors-same time. Assuming some kind of lubricant has "dried" out?? And the mirror just binds on the dry rubber pad plus straighten out the pins. Getting into winter now so I might not get to the fix anytime soon..........but when I do, I'll definitely post back.
Old Dec 13, 2021 | 12:49 PM
jimzpsd's Avatar
jimzpsd
UPDATE on fix. I followed the video and sure enough that was the cure, I wiped down all mating surfaces that slide against each other, applied a low temp tolerant lube to same mating points. Took me ten minutes each side (on my driveway).
Old Dec 13, 2021 | 05:54 PM
Lucky you huh.... This forum is a great resource. Good to see it was painless
Old Dec 13, 2021 | 09:14 PM
jimzpsd's Avatar
jimzpsd
It should be a preventative maintenance, there was so much crud in there, dirt, bugs...reminded me of cleaning out my dogs ears lol
Frank79
Sep 1, 2021 07:10 AM
makthenif
Oct 5, 2011 01:05 PM
foodog2
Oct 3, 2005 09:27 PM
93SplashMan
1983 - 2012 Ranger & B-Series
Nov 14, 2001 02:32 PM
