2021+ F150 Discuss the 2021 Ford F150
Sponsored by: Real Truck
Clock getting reset
Old Dec 8, 2021 | 09:08 AM
PhilPalmiero's Avatar
PhilPalmiero
Clock getting reset
For two days in a row I’ve gotten In my truck to find the clock reset. It’s not just a time zone change but the time is changed to a random time. Anyone else experience this happening to them?
Old Dec 8, 2021 | 07:29 PM
GABAR's Avatar
GABAR
Do you have it set to GPS time?
If so, disable it.
Old Dec 9, 2021 | 12:29 PM
PhilPalmiero
If so, disable it.
Is this setting in the Clock section of Settings because I just see Auto Set option. I will turn it off, reset the clock and see if that resolves the problem.
Has something happened with a satellite that caused this error all of the sudden?
Old Dec 11, 2021 | 07:19 PM
GABAR's Avatar
GABAR
I hope this setting solves your issue.
Whenever I would have this setting on, the clock would always revert back to the wrong time.
Old Jan 5, 2022 | 03:03 PM
Drew1295's Avatar
Drew1295
Just a heads up, but you may have an APIM (Auxiliary Protocol Interface Module) issue. My truck has an issue where it keeps changing the radio station on its own. I was told by my service advisor that they are replacing a bunch of these under warranty right now. Symptoms include changing radio stations and the clock and other presets constantly being reset.
Old Jan 12, 2022 | 07:56 PM
Frdtrkrul's Avatar
Frdtrkrul
I'd give it some time. Others may have this same issue and dealerships will probably pester Ford for a fix, and send out an RRT which would probably be a radio software update that may end up fixing the problem. Or ask your dealer if there's a fix for this problem out now for it like maybe an active TSB or RRT for it.
PumperMike
Aug 11, 2023 08:47 AM
golfmedik
6.7L Power Stroke Diesel
28
Sep 13, 2019 01:39 PM
Green Streak
Ontario Chapter
Oct 29, 2007 11:33 AM
dbanghart
1983 - 2012 Ranger & B-Series
Jun 17, 2005 08:42 AM
