79 E350 cutaway 7.5l 460 ( fuse box)
Hi Chris. I remember reading a post that Ford used the same fuse block for quite a few years. I looked at my 1981 EVTM and the "fuse block itself" is the same on the 79 and 81. I can not say for sure about the wiring but it appears to be the same also as the fuses are the same amperage.
Here is a page from my EVTM. I copied the fuse block, turned it upside down, and pasted it under the original diagram because you have to read it upside down!
Let me know if this diagram is correct. According to the diagram the blown fuse in #11... Turn signals, windshield washer, and backup lights
Check to see if your turn signals, windshield washer, and backup lights are working.. They should not be..Something caused the fuse to blow.
Here is an extra page for you that explains the circuit breaker used for the windshield wipers and a little about fuse links as there are several on our vans..
The following users liked this post:
BTW here are a couple of manuals that will help you out greatly now and in the future..
1979 FORD ECONOLINE WIRING / VACUUM TROUBLESHOOTING MANUAL EVTM $15
https://www.ebay.com/itm/361757209328
1979 Ford Truck Shop Manual CD F100 F150 F250 F350 Bronco Pickup Ranger Repair $36
It does include E100 -E350 though it is not in the title. If published by the same company my 85 and 88 van manuals are from. It includes all the F series and Bconco because there is a lot of overlapping information as many of the parts were interchangeable and many of the repair producers are the same..
https://www.ebay.com/itm/16136366591...3ABFBMnuSzsLJf
Vern Anderson
11-19-2004 09:45 AM
