My 1976 F-250
#1276
#1277
Good question, I can't remember the size, but it is the same size as the pcv valve.
Going to bed now, but can check tomorrow if you want.
Mine has grooves in the bores coz apparently it improves torque.
I forgot that you'd made a comment about open versus 4 hole spacers.
I remember reading about the differences, but can't remember them either.
#1278
It’s possible that the comparisons have been made, but the only ones I’ve ever seen were all involving throttle-body fuel injection systems.
I’ve never seen a back to back test of open versus individual bores done with carburetors.
With TBI at least, the open bores had a slight advantage over the individuals. Better idle and off-idle throttle response were some of the benefits I believe.
The following users liked this post:
#1280
#1281
The following 2 users liked this post by beardedcap:
#1282
#1283
#1284
Paul, these pictures were taken in Aug 2020 just up the road from me.
The gentleman on the left is my good friend Geof, that's who I bought my truck from.
Brad Lovell called him and said they were on their way from doing the Rubicon Trail to Moab
and didn't want to stop in Richfield for dinner and draw a crowd to see the "new" Broncos so
he asked Geof and his wife if they would feed them. These guys did the majority of the R&D for the new Bronco.
Those three Broncos were 3 years old at the time the picture was taken.
Geof has worked on Brad's pit crew and Fire Guy's Racing out of Colorado.
The open plenum space makes sense to me, does it really help??
Who knows.
#1285
#1286
The PCV valve is also 0.44''.
Go ahead and fit the UBK spacer once you're finished, and try it out.
Then fit the 4 hole spacer and try that out.
I doubt you'll feel any difference, but it will/should satisfy any and all curiosities.
If I remember correctly, the 4 hole spacer favors torque, and the 1 hole spacer favors HP.
#1287
#1288
I use the rear carb port for the brake booster, and don't really like seeing a connection to the intake.
Purely esthetic.
#1289
#1290
that's what I was referring to is the typical large port on the back of holleys and edelbrock has a provision for it as well, I believe it's a 3/8". After I said that I remembered I do have my brake booster going to my carb and my PCV is going to that fitting on the #4 intake runner, which I don't necessarily like either. Now I'm thinking I may get a T fitting and put both my PCV and booster to the carb. I get the idea of what they're doing with the spacers as opposed to using one intake runner for all of your vacuum source. I could see it causing a lean condition for that cylinder. I'm kind of confused at wanting more air through a PCV valve though.
