Does anyone know if the 2011-16 frame and the earlier 2008-2010 frames are similar enough to be swapped between model years?
I need a 137” wb 5.4 manual 4wd frame for a 2010 f250 that was rear ended. There just aren’t many 2008-2010 gas trucks in yards around here. I can find decent 2011+ Part trucks for sale local.
I am specifically talking about the frames. I realize the engine and engine mounts are different. I will have the old truck and the new frame side by side if I need to drill holes for brackets etc.
A car-part.com search resulted in gobs of them, a dozen in VA alone. It appears that you need a 2008-2010 frame, but they don't differentiate for manual or 4WD.
