F150
Old Dec 5, 2021 | 03:47 PM
slbugs0247's Avatar
slbugs0247
F150
Can you put an automatic crankshaft in a standard?
Old Dec 5, 2021 | 07:50 PM
Conanski's Avatar
Conanski
There is no such thing. What motor are you working with?
Old Dec 6, 2021 | 12:10 AM
slbugs0247's Avatar
slbugs0247
The engine is a 4.2 automatic & I'm replacing it with another 4.2, which has a stick shift crankshaft but I want it to remain automatic. If I'm asking it right?
Old Dec 6, 2021 | 08:50 PM
Conanski's Avatar
Conanski
The motors are the same, when mated with a manual trans a bearing is inserted in the end of the crank to help carry the trans input shaft. That isn't needed with an auto trans so you just need to remove the bearing.
Old Dec 6, 2021 | 09:19 PM
slbugs0247's Avatar
slbugs0247
Thanks so much....
Old Dec 8, 2021 | 06:52 PM
PROSTOCK's Avatar
PROSTOCK
Your next question should be, "How do I get this out?" There are many tricks to do so.
Old Dec 8, 2021 | 07:10 PM
slbugs0247's Avatar
slbugs0247
Do you have any suggestions?
Old Dec 25, 2021 | 06:45 PM
5851a's Avatar
5851a
96 Ford Flareside
2015 - 2020 F150
Jan 14, 2014 08:13 PM
