Misfire
Old Dec 4, 2021 | 08:34 PM
hotfalcoon's Avatar
hotfalcoon
Misfire
Trucks been running poorly for a couple of weeks.
It’s a 2004 F150 5.4, read code p0304. I replaced the coil on cylinder #4 no change today I changed the spark plug which was a little intimidating but it came out without breaking and now the truck is running good again.
Old Dec 4, 2021 | 09:28 PM
70f100longbed's Avatar
70f100longbed
Now its time to do the other 7 along with the coil boots.
Old Dec 6, 2021 | 09:33 AM
redfishtd's Avatar
redfishtd
Try to clean snout area of cly with carb cleaner when plug out . Carb cleaner will dissolve carbon that grabs snout of plug , just don't drop anything into cly .Replace all plugs and boots, scape and clean tabs on coils ,use contact cleaner .
Its wise to use a very small amount of anti-seize on spark plug threads, nickel based is best , don't use copper .
Boots are damaged by age/heat/antifreeze/oil . Do it right and it will last 60k miles . I like to use anti seize on coil hold down bolts also .
makthenif
1997 - 2003 F150
Apr 24, 2014 08:49 AM
sparkplug91
2004 - 2008 F150
Dec 11, 2011 08:32 AM
dbredinger
1997 - 2003 F150
Jun 8, 2010 09:39 AM
twelker_04
1997 - 2003 F150
Dec 15, 2009 08:26 PM
njxlt
Apr 21, 2009 07:07 PM
