Generator Welder Combo
With regards to welding I do not have a clue what would be my best alternative for primarily welding floor pans, and basically sheet metal repairs/replacement?
Suggestions and comment appreciated.
Miller Welding machines are my personal favorite. Contact your nearest welding supply store. The sales rep could steer you to the right machine. Wire welding is not my favorite process. Stick & tig are.
Good luck, Pete
Again, I thank you!!!
Having restored a '46 ****** and doing several body panel patches I used .030" wire in a mig machine with pretty respectable results. Do consider purchasing "easy-grind" wire.
If possible, consider .026" if possible using the argon mix shielding gas.
I have a 110v Lincoln mig using flux core wire and .035" wire for outside repairs. Has bad spatter.
Seems .035" is the smallest available for flux-core wire. Too heavy for thin material comfortably.
I bought a 225 Linde mig machine new in '84 just for the ****** restore and ran .030" wire through an .035" liner, which worked, but I should have purchased the .030" liner. I run .035" wire in the 225 machine for all round welding, as I am seldom welding body panels.
Ok, this is a Ford forum, so I will fess up then already. hahahaha
When doing a frame-off build of my '77 F-350 longbed Crew Cab in 1997, I welded up 65 holes in the body, doors, fenders and box. I did use my 225 amp mig machine. Was feeling ready for happy hour after welding up all those holes. _ _ _ _ then realized, _ _ _ the window glass was rolled down into the doors. Yep, so had to purchase new (wrecking yard) tinted glass for all 4-doors !!!!
As much planning as we can do to circumvent "boogers" it is a guarantee of happening. hahahaha
Have fun shopping
What power source do you have right now?
I came from a family of welders and even though I didn't make my living doing that I did maintain an aircraft certification for many years.
The work you are talking about doing isn't going to require a big fancy machine. If you have 120V / 20amp power, you can run one of these little Lincolns.
You don't want to use flux core wire on sheet metal repair, it will cause all sorts of misery and look like S$$$. You need to use gas shielding, buy or rent a bottle of mixed gas C25= 75% CO2, 25% Argon. The only drawback to using shielding gas is it doesn't work well outdoors if it is really windy.
Also keep in mind if you have to use a generator to run one of these machines and if it has any electronics in it, it will be very sensitive to the input cycles. If you can't maintain a constant 60 cycles it will kill your equipment.
Last edited by Crop Duster; Dec 4, 2021 at 01:12 PM. Reason: Bad link, removed it.
It appears I am faced with the dilemma whether to purchase a generator that can handle the requirement of the Lincoln 155, or purchase a new portable MIG Welder. Finding the combo welder/generator is far too expensive for my needs.
The least expensive option and probly the best option would be to replace the 155, and now a matter of doing the research Lincoln vs Miller regardless of which brand it is going to be a learning experience and likely screw up a few welds.
I have Eastwood power tools purchased years ago and still going strong; however, lately I have been purchasing power tools locally finding it much easier to deal w/ supplier face to face.
I can not thank U'alls enough for your sources, information regarding types of material and power required to operate the equipment along with comments and suggestions.
And if you keep your eye on Craigslist, etc, look out for a Miller Cricket(70A) or Cricket XL (90A),**With a gas kit !! These machines are getting old enough that there should be some good deals if you happen across one that was used only occasionally by a hobbyist. My first home mig (circa1989) was a Cricket, good little machine, provided you're not trying to weld heavy stuff
They will weld with either solid wire, or flux core, but you have to change polarity to switch from one wire to the other. **And the rule of thumb is you need an amp for every thousandth of thickness. (and as always, there are exceptions
.James
I have an old SP-100 that I got in a trade 30 years ago. It may be a little more powerful than the 2185 but it's basically the same machine. Bullet proof little critter.
Ran a search and found Lincoln equipment distributors in my area are thru a 3rd party, not an issue as long as the local distributor provides service repair and or returns.
The closest welding supplier in my area is Miller where I recently purchased replacement nozzles and some welding rod spools for the 155 which I do not think will be a problem since it appears majority of the items purchase should fit most MIG welding unit applications.
Crop Duster, the link works for me I thank you, bookmarked for future references.
Been checking local and Ebay sources, considering the cost for a new replacement likely go that route and most importantly with research and inquire determine if local supplier would be a viable option.
I be thankin U's all again, stoked with all the great information and suggestions, hope to purchase replacement w/in the next couple weeks???
I be thinkinr. since there a several mobile welder businesses in my area explain what I am trying to do and whether they would make a home visit, check out the 155, provide basic instructions on how to operate it, and any other information he/she can provide based on their experience.
Mentioned I prefer purchasing locally but find local Airgas and Miller suppliers send the equipment out to their service centers.
Tomorrow, Monday I will be making some phone calls.
Thank you for the input!!
