death wobble
Old Dec 2, 2021 | 08:49 AM
grege's Avatar
grege
death wobble
Had the death wobble on my way to work this morning. Man was that scary. Had always been worried about going over bumps when on a highway but had gone almost 4 years without it happening. Tried to go on the NHTSA website to report it but they didn't like my VIN and I know I am entering it correctly. Weird.
Old Dec 2, 2021 | 05:09 PM
ERE's Avatar
ERE
Had my 1st DW last week, just under 42,000 miles. Going in the shop in the AM.
Old Dec 2, 2021 | 05:14 PM
grege's Avatar
grege
I'm at 73,300 miles so I guess I should feel lucky. lol Hopes it's not like a disease where once you have it you are more likely to get it again.
Old Dec 2, 2021 | 05:21 PM
Jmac5058's Avatar
Jmac5058
4wd High
Its like seperating your shoulder , after you do it once the next one is just a matter of time .
Old Dec 2, 2021 | 05:28 PM
morehouse7's Avatar
morehouse7
You have a worn part to find in your front end, your truck is just letting you know with a courtesy shake...
Old Dec 2, 2021 | 05:54 PM
morepower02's Avatar
morepower02
I guess I’m just lucky. 1999 F350, 2002 F350, 2006 F350, 2008 F350 and 2015 F350. In the last 22 years I’ve never had a “death wobble”. I’ve got 100% confidence my ordered 2022 F350 continues the trend.
Old Dec 2, 2021 | 06:14 PM
NewEnglandHerdsman's Avatar
NewEnglandHerdsman
Check the track bar for any amount of play at both ends. That's almost always the culprit. A new stabilizer may cover up the problem, but won't really fix it permanently.
Old Dec 2, 2021 | 07:47 PM
husqvarna's Avatar
husqvarna
What year? My 2017 had it happen a few times, but the dealer finally did some fix that Ford recommended, and it's been fine ever since. I'm hoping my new 2022 doesn't do it.
Old Dec 2, 2021 | 08:17 PM
grege's Avatar
grege
Well damn. Is there anything that can be done?
Old Dec 2, 2021 | 09:47 PM
TX Chris's Avatar
TX Chris
See post #7 above.
Old Dec 2, 2021 | 11:22 PM
JDski's Avatar
JDski
Yes, grere, there is. Watch this video. It describes what the problem is, what to check and replace then it describes why more castor is needed than the factory set up to resolve death wobble for good. There are multiple castor kits on the market. Some are pretty simple fixes and others are expensive and require extensive work to install.
Old Dec 3, 2021 | 08:30 AM
grege's Avatar
grege
Thanks for all the info everybody.
Old Dec 4, 2021 | 07:33 AM
Norcalpr's Avatar
Norcalpr
Literally copied and pasted from another thread on the next page...
Its simple. You have something worn (anything in the front end can cause it... balljoints, tierods, bushings, drag link, steering box, tires, shocks.....). Replace the worn components and it'll go away.
The problem with the DW threads is people say, "oh its this, replace this and it's fixed" or "it's a bad stabilizer, throw on a dual stabilizer and it's fixed"
It's not that simple. Every truck is different and remember that there are a bunch of components working together to keep the front end from going into a shake. If one of those items is worn, a bump will exploit the play and The shake will start...
Start by having someone move the steering wheel back and forth quickly when the truck is on the ground and stopped, and climb under there and inspect everything for play. Then jack the front end up and start checking everything.
Just my 2 cents, the dealership is worthless when it comes to this. They will do the cheapest and laziest fix, just to get you down the road far enough until the wobble will start again (but hopefully it starts again out of any warranty period so they can get you back in again for more money or a new truck)
Old Dec 5, 2021 | 11:02 AM
Realwickedone's Avatar
Realwickedone
Death wobble
LMFAO...looks like we're both on the same frequency for new trucks....and like you I've never had it....read about it...seen a couple videos of it...and about 3 months ago a Co worker told me it happened to him...otherwise I don't know anyone who has experienced it....
Old Dec 5, 2021 | 03:26 PM
NewEnglandHerdsman
I hope your good fortune continues. I have had it happen in at least three trucks, the first being a 1976 F100 4WD with - you guessed it - a solid front axle and coil springs up front!
mikejones202
Nov 6, 2021 06:22 PM
chadstickpoindexter
Sep 18, 2021 08:49 AM
Cavalier240
Dec 11, 2017 08:43 AM
190 jerry
Jul 6, 2012 08:20 AM
1997F-350
21
Nov 11, 2007 09:50 PM
