Bronco II Ford Bronco II
ATF vs 75W-90 ?
Old Nov 4, 2003 | 10:55 AM
JMKiser's Avatar
JMKiser
ATF vs 75W-90 ?
I have an 87’ BroncoII with a manual five-speed transmission. I have been told that this particular transmission requires a combination of both ATF and gear oil, like regular 75W-90? Could this be correct? All of the documentation for the transmission leans toward the standard 75W-90 gear oil, but in very cold weather the transmission is almost impossible to shift into first gear. After the vehicle is warm then it will shift as usual. Any comments or ideas would be greatly appreciated.
Best regards,
John
Old Nov 5, 2003 | 06:04 AM
Zayazz's Avatar
Zayazz
What kind of transmission you have - Mitsubishi or Mazda?
If Mitsubishi - then 75W-90 syntetic - that's great (need at least 80W)
If Mazda - then ATF as it's.
I have Mitsubishi 5-speed/ Previous ovner put on it ATF. After changing it to the 75W-90 - work like clock!
curkey
Oil & Lubrication
Apr 25, 2013 12:05 AM
5504x4drwcrew
Nov 2, 2011 07:12 PM
DarrellinCeres
Jul 19, 2011 09:16 AM
cdat81986
Mar 2, 2011 11:07 AM
terran05
13
May 20, 2007 08:53 PM
