Speedometer Help!
Old Dec 1, 2021 | 09:21 AM
62FE4x4's Avatar
62FE4x4
Speedometer Help!
Speedometer help! I have a 94 F350 with Speedometer issues. Usuallycwhen this happens I replace the ABS Sensor in the rear end but this time (and 3 sensors later) no luck. It'll work 30 seconds or so then do a little dance which kicks off my cruise. Any suggestions? Thanks!
Old Dec 1, 2021 | 10:19 AM
sandymane's Avatar
sandymane
Have you checked fuse 18?
Old Dec 1, 2021 | 10:27 AM
62FE4x4's Avatar
62FE4x4
Fuses good
Old Dec 1, 2021 | 10:43 AM
sandymane's Avatar
sandymane
When you say ABS sensor are you talking about the VSS on the differential?
Old Dec 1, 2021 | 10:45 AM
62FE4x4's Avatar
62FE4x4
Yes the rear ABS that screws into top of hoghead
Old Dec 1, 2021 | 10:56 AM
sandymane's Avatar
sandymane
I am no expert on the PSOM and tone ring but either could cause your issue. Do a search or Google those items and see what you think,
Old Dec 1, 2021 | 10:58 AM
62FE4x4's Avatar
62FE4x4
What is the PSOM and the tone ring? Is that the magnet inside the differential?
Old Dec 1, 2021 | 11:00 AM
sandymane's Avatar
sandymane
PSOM is the "computer" for the dash speedo odo etc. Yes the tone ring is the magnet. You might try cleaning it and the sensor of metal shavings and see if it works.
Old Dec 1, 2021 | 11:03 AM
sandymane's Avatar
sandymane
PSOM Programmable Speedometer/Odometer Module
Old Dec 1, 2021 | 11:05 AM
62FE4x4's Avatar
62FE4x4
I tried to get a speedometer and a gauge cluster, but nobody in the country has either one. A new Sensor last about three days before it is full of shavings again. How do I access the tone ring? Is there a way I can spray brake cleaner through the hole the sensor goes in to clean it?
Old Dec 1, 2021 | 11:13 AM
sandymane's Avatar
sandymane
I think the tone ring must be the issue if covered in shavings and not getting a signal. The folks on the forum usually get PSOM's from the JY.. Let me look in my files and see if I can find a good video on replacing the tone ring. I don't think a quick squirt contact cleaner would hurt anything in the tone ring. The break cleaner may work with a quick squirt but I'm not sure of any possible consequences with the brake cleaner. If mine and that's all I had I would try a little.
Old Dec 1, 2021 | 11:20 AM
sandymane's Avatar
sandymane
This is long and might be more than you need but you should get a good idea of the tone ring replacement.
Old Dec 1, 2021 | 01:10 PM
foresixtee's Avatar
foresixtee
is it the original speedo?
Old Dec 1, 2021 | 02:01 PM
rla2005's Avatar
rla2005
If the metal shavings return in 3 days you have an issue with the bearings and possibly other parts in the rear axle. It's going to take more than a simple tone replacement to fix your problem.
eagle275
Apr 26, 2019 12:03 AM
scubajt
Jul 9, 2011 10:05 AM
Midwest Dually
1983 - 2012 Ranger & B-Series
Jul 8, 2011 12:10 PM
davidcam
Mar 21, 2008 08:47 PM
Cuda444
Oct 25, 2004 07:28 PM
