Sponsored by: Real Truck
2012 6.2 AC Bypass HELP !
Old Nov 30, 2021 | 09:24 AM
mtnxtreme's Avatar
mtnxtreme
My AC has **** the bed, totally seized and I need this truck today, does anyone know of a shorter belt that will fit without the AC so I can get back on the road ? And my local parts guys want 500 bucks for a compressor, its 20 degrees here so I can do without till spring. I heard of a bypass pulley with stock belt but was hoping for a shorter belt we can just throw on without that to get us going ?
Old Nov 30, 2021 | 10:47 AM
I.B. Washincars's Avatar
I.B. Washincars
Can you cut your old belt and route it the way you desire? This should give you a ballpark idea of the length you would need.
Old Dec 1, 2021 | 10:46 AM
mtnxtreme's Avatar
mtnxtreme
In case anyone need this info down road, you cannot run a shorter belt it will hit a coolant line and theres no way around it. I went the junkyard route, 90 bucks for the compressor, 6 month warranty, put some AC oil in it and away we went. If you want to delete the AC you can get a bypass pulley for like 20 bucks to run with the factory belt size. Those are the options.
Ryan Drummond
2009 - 2014 F150
Jun 24, 2024 04:31 PM
Carny
Dec 18, 2009 10:37 PM
XXL Supreme
Mar 9, 2007 12:17 PM
Billy Bronco
1978 - 1996 Big Bronco
Oct 21, 2004 05:53 AM
signal
Jun 27, 2004 08:13 PM
