F250 Payload Capacity?
Old Nov 29, 2021 | 09:59 AM
aagiv's Avatar
aagiv
Hand written sticker is probably from a company that added utility box/flatbed/whatever. I own a minivan modified with a wheelchair conversion, and it has a handwritten tire sticker applied over the Toyota original sticker.
Old Nov 29, 2021 | 10:03 AM
Wheels_On_Fire's Avatar
Wheels_On_Fire
Originally Posted by Ford8502
Wow, never seen a hand written sticker before! But who would have a blank sticker and why would it be de-rated? Does this truck have custom wheels, or a special dealer package?
Well, if it was ordered as a chassis cab, I assume that it was shipped to a second manufacturer that would add whatever box was put on there. That would explain the "incomplete vehicle" sticker from Ford.
The second manufacturer got the unfinished chassis cab, installed the big heavy utility box (or whatever) on it, and then calculated remaining payload with that heavy thing in place. That explains the low payload and hand written sticker.
Then at some point between then and me purchasing it, the owner decided they'd rather have a normal truck, and swapped out for a regular 8ft bed. They should have uprated the stickers at that point, but I can imagine that would be a bit of a pain in the butt so they opted to skip it.
Old Nov 29, 2021 | 10:09 AM
scraprat's Avatar
scraprat
Top Answer: 5
Now we know the rest of the story that fills in the blanks.
Old Nov 29, 2021 | 10:15 AM
CR250Bronco's Avatar
CR250Bronco
I would remove that hand written sticker. It doesn’t even apply anymore with the standard bed on it. You have 3,180 payload which sound right.
Old Nov 29, 2021 | 10:24 AM
4wd6.7L's Avatar
4wd6.7L
...it would have been even higher than 3180lb on sticker if it was originally a complete pickup. Payload on sticker would have been based on curb weight with a full tank and no occupants. At this point none of that matters, you got your scaled weight and other pertinent factors.
Old Nov 29, 2021 | 10:25 AM
Wheels_On_Fire
The actual payload should include the passengers and equipment, right? I think that would probably put it closer to 3600-3800, which makes sense when compared to the Ford spec sheets (which say 3910)
Old Nov 29, 2021 | 10:47 AM
mark waller's Avatar
mark waller
Full tank of gas no people or payload.
Old Nov 29, 2021 | 10:57 AM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
I bet actually not technically a chassis cab, but a pickup box delete.
Chassis cab comes with a straight rail frame, so mounting a pickup box on it would be a problem.
JD'sBigredv10
Sep 8, 2021 07:37 PM
StefBala
All Things Towing
15
Aug 4, 2018 03:10 PM
1975-F6004x4Dump
Large Truck
15
Feb 12, 2014 01:46 AM
sbennett
All Things Towing
13
Nov 15, 2004 11:49 PM
rafterjf250
Jul 7, 2001 10:34 AM
