Viberation at 55 mph
Old Nov 28, 2021 | 06:04 PM
ethanmom's Avatar
ethanmom
I use the nvh app it says I have 1st order tire speed related virabation it vibrates at 04 expedition
I had my tires road force balance it didn’t solve the issue any suggestion
Old Nov 28, 2021 | 09:43 PM
am122's Avatar
am122
4wd Low
I replaced my brake rotors to fix the vibration on my 03 Expedition.
Old Nov 29, 2021 | 09:32 AM
Hamfisted's Avatar
Hamfisted
Have an alignment shop check the front end parts for you. Typical culprits are the inner tie rods and/or the lower front ball joints. If you're getting a click from the rear corners in early morning slow speed sharp turns it is probably the rear lower "ball joint bushings" too.
Martynka
Nov 25, 2019 12:44 AM
chrison600
Apr 20, 2013 09:30 AM
davewave649
Feb 10, 2012 07:24 PM
bommerts
Jan 18, 2012 06:21 AM
vaindioux
33
Jan 12, 2011 12:52 PM
