anodes
Old Nov 28, 2021 | 10:25 AM
dustyroad's Avatar
dustyroad
anodes
Anyone using an anode in their cooling system? How do you have it installed?
I've seen 2 styles but neither seem to work for our trucks. (I could be blind too) The cap and the petcock style.
Old Dec 3, 2021 | 09:39 AM
BigBlue2's Avatar
BigBlue2
I haven't tried the anodes. Looked into them as I was having radiator leak problems. Sometimes you have a current running through your cooling system that can cause problems. At one point I did have a problem with a bad alternator that had a partial short to ground. I looked up on line how to test the radiator for stray current. Recommend you google that procedure. It involves opening the radiator while running and suspending a copper wire or tube into the radiator with out touching the sides of the radiator. You want to have as much of your copper probe immersed as possible. Connect the multimeter to the copper probe and the other end to ground at the battery.
I can't remember the maximum amount of current that's deemed acceptable but it's tiny and you'll want to use a quality multimeter to measure that. If you have stray current then an anode is just a bandaid because your problem is being caused by a stray current coming from somewhere.
Old Dec 3, 2021 | 10:11 AM
dustyroad's Avatar
dustyroad
appreciate feedback and the lesson even if I wasnt asking how.
I am aware of testing the system for current and ph.
I'm installing one as prevention for dissimilar metals not feedback current in my case.
I'm just going to stick mine in the overflow, better than nothing. Suppose I'll be the only one here.
Old Dec 3, 2021 | 10:19 AM
BigBlue2's Avatar
BigBlue2
If I was going to use one preventitively I'd go with the anode cap. Easy to monitor it. Stant makes one IIRC.
flowney
16
Jan 20, 2018 01:48 PM
14SD4Jeffro
Dec 9, 2016 08:55 AM
Aaron-71
Jul 7, 2015 09:35 PM
David LaPell
Aug 25, 2014 07:15 PM
joe blow
Aug 29, 2012 06:10 PM
