Aerostar Ford Aerostar
catalitic converters
Old Nov 4, 2003 | 09:08 AM
buffalobill's Avatar
buffalobill
I need to replace my whole exhaust system, but I'm a little confused about the converters. Its a 1993, 3.0L it has 2 catalitic converters and is the pipe from the manifold to the second converter all one huge piece? Thanks for any help!!!
Old Nov 4, 2003 | 12:14 PM
aletheuo's Avatar
aletheuo
If it's anything like the 4 litre you'll have fun. Me thinks it's all one piece of of the factory. Nothing short of a cutting torch is gonna get you very far. The pipe between the two cats is routed under a cross member of some kind. You'll likely have to either remove the cross member or cut between the cats to get them out. I'm not sure it's feasible to expect to get them out in one piece.
Old Nov 4, 2003 | 08:15 PM
Berry's Avatar
Berry
I had both converters replaced on my 3.0 for $120.00 at my local muffer shop. The tech cut the old ones off and welded the new ones on in less than 45 minutes.
canadianfordman
Mar 30, 2012 10:13 AM
andyj ford driver
Oct 1, 2010 01:28 AM
scfd43
Aug 27, 2005 06:29 AM
BOJOFASO
1978 - 1996 Big Bronco
Mar 11, 2003 12:39 AM
erich64
15
Aug 17, 2001 10:38 PM
