Axle pivot bushing part # help.
Old Nov 27, 2021 | 01:42 PM
Rogue427's Avatar
Rogue427
Question Axle pivot bushing part # help.
Putting disc brakes on my 71 F350 2wd.
I bought a complete 1973 F350 frame with disc brakes. I pressed out the axle pivot bushings and they are smaller then the new ones from the parts store. Bout are oval.
1973 disc setup measures 1.5" across and had 9/16" bolt for the pivot bushing.
1971 brake setup measures 1.7" and 5/8" bolt.
Moog K8179 would work on the drum setup and mevotech MS40495 is the same.
Thank for any help.
Old Nov 27, 2021 | 07:23 PM
JEFFFAFA's Avatar
JEFFFAFA
What are the stamping numbers on your I-beams? How much smaller are you talking about? Did you press out the outer metal shell along with the rubber?
Old Nov 28, 2021 | 09:09 AM
Rogue427's Avatar
Rogue427
Yes , I pressed out the outer metal shell.
I will look for stamping numbers today.
NASHMAN619
Aug 10, 2019 09:26 AM
sgprecision
Nov 5, 2010 06:23 PM
wbtguy
Oct 7, 2003 10:33 AM
MustangGT221
Nov 10, 2002 09:18 AM
