1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Transmission fluid leak from the top
Old 11-25-2021, 07:20 PM
roboford's Avatar
roboford
roboford is offline
Hi everyone,
I have 08 F250 5.4L with 5r11w transmission. After chasing the leak for a while, I found out my truck was leaking on the top of the transmission. I reduced some fluid and the leak stopped, however, the level look low now. After the truck has been running for about 40 minutes, the level barely touch top of the stick (below the c range) measured while the engine was still running. Does anyone experience this symptom?
Thanx
Old 11-25-2021, 08:31 PM
Evan_P's Avatar
Evan_P
Evan_P is offline
You need to determine where it is leaking from. I would not leave the fluid level low.
Foxdox9
02-09-2022 08:23 PM
BAD RONALD
18
05-25-2019 03:58 AM
hharris8
08-11-2016 10:04 PM
sudsmcduff
08-29-2013 08:27 PM
ustolemycupcake
03-03-2005 07:31 AM
Quick Reply: Transmission fluid leak from the top
