FUEL TANK PURGING
Old Nov 22, 2021 | 08:58 PM
sandymane's Avatar
sandymane
FUEL TANK PURGING
I have read about my issue and don't have a target solution yet.
Today my front tank was just below 1/4. I started adding fuel and after less than a minute it started to purge. I stopped it and resumed filling without incident. It happened once before awhile ago.
The tank only registered 1/4 tank when I left and after 5 miles it went to the proper level for the fuel I had added. This has been happening the last few times I have added fuel to the front tank. I and several here on the forum attributed this to a sticking float. I don't think this is associated with the purging, but I don't know.
Any idea of what might be causing the purging? Gas cap is a fairly recent Motorcraft. Rear tank works as it should. Thank you in advance.
Old Nov 23, 2021 | 02:22 PM
SFaulken's Avatar
SFaulken
Honestly, I don't have a good read on what the issue might be. I had some similar issues with the rear tank on my '92 Due to a pinched off vapor line where a PO had crushed the bed down on top of the soft line. Maybe check that you don't have an obstructed vent? I will say, and I'm not being paid to say this, I run a bottle of Chevron Techron additive through my OBS trucks about every third or fourth tank, just to keep the sending units happy. I don't know what Chevron puts in there, or if I'm just lucky, or if it's confirmation bias, could be anything, I'm neither a chemist, or petrochemical engineer, but I've had it both "bring back" senders from the dead, and keep them from weirdness.
Old Nov 23, 2021 | 02:27 PM
sandymane's Avatar
sandymane
Thank you. I will check it out. When I posted about the possible stuck float, I had mentioned I used some MMO and it started working. You replied you had success with it also. Think the Chevron might be better since the problem returned?
Old Nov 23, 2021 | 04:21 PM
SFaulken's Avatar
SFaulken
Its been my go to, when nothing else works. I've had better success with it, than with MMO. I generally choose the MMO when I've got a tank with rust issues, vs Techron.
Old Nov 23, 2021 | 04:38 PM
JJF20's Avatar
JJF20
Good to know Faulken, I’ll keep that in mind. As Sandy, MMO has always been my go to.
Old Nov 23, 2021 | 06:05 PM
sandymane's Avatar
sandymane
There is a clip that secures my tank vent. It appears that after 30 years the hose may have gotten weak and given some at the clip. I readjusted the hose and put the clip in a new spot. Will see what happens when I add fuel again. I will try the Chevron if the float acts up again. Thanks for the suggestion.
OlBrownTruck
Oct 2, 2021 05:21 PM
Hiddencamper53
Apr 16, 2016 05:59 AM
cowmilker08
Mar 25, 2009 03:36 PM
2pfspiff
32
Sep 23, 2007 12:01 PM
scozim
Jun 11, 2006 12:14 AM
