Valve Seals
Old Nov 4, 2003 | 12:39 AM
nightme_02's Avatar
nightme_02
Valve Seals
Could anyone that has done this before give me some ideas of what to expect, and also any hints or suggestions that you can pass along?
I know that my seals are pretty well shot when I have a cold start (>40 degrees F) I tend to fog the yard! With 164,000 miles I assume it is getting close to the day that it needs done anyways. Can you use a vacuum pump to see how my "leaakage" there is, and how does that work. I have access to the pump, but what types of connectors will I need...do I just try it in all the spark holes (only on 1 side though) or is there a "special" place that it should be done in!
I have the haynes and chilton manuals, and to me they are not clear enough for me to be sure I won't be causing more harm then good!
Thanks guys preciate it
Old Nov 4, 2003 | 12:40 AM
nightme_02's Avatar
nightme_02
forgot something
94 2.3L 4 bander (black with a grey stripe!)
Old Nov 4, 2003 | 06:50 AM
wolfen's Avatar
wolfen
Hi nightme_02,
If anything it's the valve ~guides~ !
Do these tests to find out what the real problem is!
You will need to perform 2 "Compression" tests on your cylinders!
Get the screw-in type tester and take down the readings from both tests!
Proceed w/1st test!
NOW...
Before doing 2nd test, squirt a very little bit of oil in each cylinder before retesting (you are now checking to see if the rings are also bad!)
If you end up w/ higher comperession, it's the rings, if not, it's the valves!
ALWAYS BE SURE!
________________________________________________
‘90 Ranger XLT: 2.3L, EEC-IV, EFI, DIS, 2wd, Mazda 5sp
Old Nov 4, 2003 | 07:02 AM
ctfuzzy's Avatar
ctfuzzy
Originally posted by wolfen
Hi nightme_02, . . .
ALWAYS BE SURE!
*Especially* when those little 4-bangers have had such a reputation for head problems.
