2006 E250 transmission code "Q"
Old Nov 21, 2021 | 10:35 AM
WoodsStalker's Avatar
WoodsStalker
Says the sticker on the door.
What transmission is it?
Just had reman motor and transmission installed.
It does not seem to use the OD function?
On expressway, 55mph is tops. Give it gas, engine rpm increases from 2200 to 3000, and starts slowing down.
Any thoughts before I contact installer Monday?
2006 E250 5.4 cargo van
Old Nov 21, 2021 | 11:57 AM
Conanski's Avatar
Conanski
That truck should have a 4R75E, does it have the OD off switch on the end of the gear shift? WIth the way it is functioning some codes would be set so checking codes may give you a hint as to what ois going on.
Old Nov 21, 2021 | 03:22 PM
WoodsStalker
Yes to the overdrive button.
Going to have to find or replace my code reader.
Last seen 10 years ago.
It is OBD2 at least.
Back soon!
Old Nov 22, 2021 | 03:59 AM
JWA's Avatar
JWA
Back soon!
Any transmission-related DTC's cannot be accessed by the typical hand-held "scanner". Retrieving those codes requires a scanner with that capability.
FWIW transmission DTC's are not indicated by the "check engine light" or MIL lamp in the instrument cluster.
Old Nov 22, 2021 | 06:56 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Most transmission DTCs are not indicated by the check engine light. Some of them are. If the EPA considers the code to be emissions related it MUST turn on the check engine light. Some transmission failures can be emission related if they put the trans in the wrong gear at the wrong time.
Old Nov 22, 2021 | 06:15 PM
WoodsStalker
Thanks for the details.
The darn thing went to work and back (60 mile round trip) just fine today. Up down, all around the 45-75 mph range. Local 35 mph areas just fine.
Overdrive does as expected.
Now up to 90 miles on motor/trans.
This is so familiar...
First work truck, 350,000 miles.
35 years in the trades.
Many many miles in E series.
It felt so good.
Old Nov 22, 2021 | 06:20 PM
WoodsStalker
On a related note, scanners...
what would be an appropriate purchase, general use, with the knowledge that I will find a cruise control steering wheel, and clock spring for CC.
That has to be $100 twords the purchase price of the scanner...
Rather than pay someone else, if you get my drift.
Yeah, drifting in a E250.
May have to check utube.
Old Nov 22, 2021 | 07:46 PM
Conanski's Avatar
Conanski
Forscan with a compatible interface for your device would be my suggestion, this combo will do everything a store bought scanner will do for free and much more with a paid extended licence.
Old Jan 9, 2025 | 12:49 PM
steven.stottlemyer's Avatar
steven.stottlemyer
1st Gear
Intermittent transmission problems… i found ecm wiring damage bc of wearing on hot egr tube !
It felt so good.
i found damage to wiring harness. Look at harness where it touches egr tube. Mine burned and shorted to ground causing intermittent transmission shift problems.
i made repairs using several 3 foot lengths of similar wire - the location of damage is difficult to reach. So - splice near ecm then other end spliced near transmission. Do one wire at a time. Not exactly easy but can be done very inexpensive.
replacing harness is also not easy. Harness is expensive.
hope that helps. These are known for this issue.
mercuryblues
Aug 10, 2021 04:33 PM
Fordmanz1973
2004 - 2008 F150
Feb 24, 2018 11:50 PM
NotEnoughTrucks2014
Apr 24, 2017 06:46 PM
