96 Ford 150 with 5.8 engine
Old May 31, 2000 | 01:47 PM
gary's Avatar
gary
I just purchased this truck about a month ago with 40,000 miles on it. It is equipped with automatic transmission and 4 wheel drive. My question is that this truck does not seem to perform as it should and was wanting to know from you all what type of bolt on performance items delivers the most bang for the least amount of money. I was hoping some of you had experimented with this and might know what might help. Any suggestions would be received well and I am thanking you in advance for your advice.
PS: I don't want a race truck, just one that is little hotter than stock.
Old May 31, 2000 | 09:20 PM
PAUL_2's Avatar
PAUL_2
Gary ,
You can add as much as your budget will allow . Maybe a K&N Air Filter , Some folks add higher output ignition systems , freer flowing exhaust systems , I think you can add a larger diameter throttle body on your engine ? A computer chip to free up some Hp . Im sure what I suggested is just the tip of what you can do . Its one of those deals that if you have the cash , someone has a place for you to spend it .
Paul
Old Jun 2, 2000 | 09:22 PM
Torky's Avatar
Torky
What axle ratio do you have? If you have a 3.55, it should really go. Check tag on rear diff for ratio encoded in.
Also, check sticker in door opening for axle code. Code 19 is a 3.55 open, H9 is a 3.55 limited slip. Don't remember sticker codes for other ratios, but if you give us the number, we can look it up and tell you.
Old Jun 10, 2000 | 06:56 PM
n5mj's Avatar
n5mj
Uncork the exhaust.
I have a '93 Bronco with the 5.8L. With the stock exhaust, it had about as much get up and go as my 4 cylinder Ranger.
So, after finding some rust rot in the tailpipe, I went to Carparts.com with a nice $100 coupon (look in this month's Popular Science) and bought a Gibson Performance Exhaust system.
Nice muffler, 3" smooth bend single pipe all the way from the cat back. The muffler slid right onto the CAT, and all the hangers matched up with the stock rubber donuts.
Very nice sound, not too loud. But what a difference in performance! NOW the 5.8L *feels* like a 5.8L should. I wouldn't have believed it, but evidently the stock muffler has lots of restriction... or rusted up on the inside?
Anyway, the whole cat-back system was drop shipped for $270. Best bang for the buck IMHO.
Good luck.
Mike
Old Jun 12, 2000 | 10:15 AM
DoubleA's Avatar
DoubleA
