Tailights and Trailer Wiring harness recommendations
I need to add wiring for a trailer hitch. I have seen many kits, and done several searches. I haven't found something I really like.
I am looking for a good trailer hitch wiring harness. Preferably, one with the full tail section already connected. I.e. I am looking for a tail wiring harness with a trailer wiring harness already connected. Does something like this exist? If so, what is a good one?
FORD Vehicle Specific Kit (hopkinstowingsolutions.com) I used these. No cutting factory wiring. Unless you have trailer special there is no way to plug in a 7 pin connector, and that is not plug and play either. The 4 pin T worked great for me.
Etrailer.com has everything you need. Fast ship, good prices and large selection. As stated above if you desire a common 7 pin RV flat plug which accommodates a brake controller, you have to order the controller and run 2 additional wires from cab to the rear, one for the brake controller signal and one for 12V+ for breakaway battery charging .....Oh and a 3rd if you want a reverse light signal on trailer. If you just need park, turn signal, and brake lights all you need is the 4 Pin T and a flat 4 pin trailer connector.
The 4 pin T plug as shown in link above is easiest to use even if you do need to run the additional wires for brakes as it prevents cutting and splicing the harness.
BillBraskey
WTB - Parts & other
06-09-2017 11:55 AM
EMD_DRIVER
11-07-2008 09:22 PM
ghettotruck
09-04-2004 09:39 PM
