Looking for a part number for the short hose (6"-8") with the white connector that connects to the hardline at the firewall. Not the green end one that goes to the intake manifold. If unavailable, how about part number or dimensions of the white connector that connects to the purge valve. If I have to I'll make one up with the connector.
Searched the web, can't believe others haven't inquired about this hose, its as crumbled as the green one I replaced.
I know I could just run a fuel tolerant hose, would prefer the connector type.
Thanks! (1999 5.4l 2V F150)
Not this one, the other one, I need the one with the white end.
Get some injecter fuel line or gas line the size you need (Not any other type of line as it will not hold up) and make one.
You can make one for less than $20.00 dollars or if can find one for around $100.00.
I will have to look up the part later when I have more time to see if it is still available.
Thanks for the assist @Stonedpony , I was going for the OE one because I thought the white connector was molded into the hose. But I looked a little deeper and yes it looks like it would be easier to just replace the hose and reuse the white connector (mine thankfully isn't brittle/broken. I did run by the local Ford place and they gave me the part number for my veh "1L3Z-9C016-AA " for the OE one. Their price was about $30, off the web for about $25 delivered. That part actually comes with the connector, hose and the short length of metal tubing that connects down just at the frame rails. Looking at the hose where the metal line connects to at my frame rail it is also pretty degraded, so with the foot of fuel line I get to replace the top line I'll replace it also (looks to be held in by spring clamps).
Do you happen to know the size, I measured as best I could and it looks to be 1/2"?
Also a sort of related question, the vapor line that goes to the intake manifold is pretty soft and pliable (it's new 3 years ago). Most fuel line I've encountered has reinforcement in it and is relatively stiff. Is there a softer "bendable" version of fuel line, similar to the intake manifold hose? I need to make a sharp 90 from the white connector down to the steel line.
