B1359 Ignition run / accessory circuit failure FIX?
2003 Ford F150 2dr XL 4.2L Automatic 2WD LB
Anyone know why this code is showing up and more importantly how to repair it?
I do not have any noticable issues but would like to fix it before I do.
While having door chimes that alert a driver that the key is still in the ignition while the doors (or any single door) are/is open is a good idea in principle, the actual chimes, and their control circuits are notoriously unreliable and prone to failure, and especially so on Ford applications.
The Ignition Switch RUN/ACC circuit provides voltage through the circuits to the Smart Junction Box (SJB) when the key is in the RUN/ACC position. The OBDII sets when the Ignition Switch signal is not factory specifications.
B1359 FORD code possible causes
- Faulty Ignition Switch
- Ignition Switch harness is open or shorted
- Ignition Switch circuit poor electrical connection
- Faulty Smart Junction Box (SJB)
- Damaged, burnt, shorted, disconnected, or corroded wiring and/or connectors in circuits that are active when the key is in the ignition, but with the ignition switched “OFF”
- Defective door chime
- One or more defective “door-open” switches
- Defective ignition switch
- Modifications to disable the door chime
- Defective PCM or BCM (Body Control Module). Note that control module failure is exceedingly rare as a cause of this code and the fault must therefore be sought elsewhere before any control module is replaced
Okay. The B1259 code is generated in the GEM when there is difference between the RUN and the RUN/ACCY circuits feeding into the GEM, presumably when the RUN/ACCY feed is absent while the RUN circuit alone is powered.
So, if there are no concerns with items that normally powered in the ACCY position, my instinct would be to call it a glitch, perhaps due to a momentary open or otherwise "bad" connection in the ACCY power circuit from the ignition switch through the fusebox and into the GEM module.
If everything works normally, I wouldn't be inclined to lose any sleep over it until such a time as other symptoms manifest.
