Carb question:
Old Nov 17, 2021 | 07:23 PM
abe's Avatar
abe
Carb question:
I took the old carb from my 54 apart tonight. After 2 days I would have to put gas in the carb to start. So I took it apart and the bowl is bone dry. And there was some dirt in it. I took this carb off last Friday. What do you think?
Old Nov 17, 2021 | 07:30 PM
38 coupe's Avatar
38 coupe
Clean the grime by spraying with carb cleaner or starting fluid. Take the cast iron base off and put some gas in the float bowl. Cover the top of the carb with cardboard or something to keep the gas from evaporating, then let it sit for a day or two. If there is a leak you should see it. My guess is either the power valve itself or the power valve gasket.
Old Nov 17, 2021 | 08:13 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Your fuel system must be dirty. What filters are you using? Has the gas tank been cleaned?
Old Nov 17, 2021 | 10:02 PM
EffieTrucker's Avatar
EffieTrucker
Phantom of the Phorum
The white stuff looks like some kind of thread sealant that has turned hard.,
I agree on the possible power valve leak. Get a good kit with good parts, not one of the cheap ones. As far as I know, Cowboy John's or Vintage Speed sell the better kits, but there may be others. I wouldn't go to Carquest, Advance, or other box stores.
Old Nov 17, 2021 | 10:22 PM
abe's Avatar
abe
New gas tank less than a year ago, new hard lines. A glass filter between pump and carb.
The white stuff looks like Teflon tape but I have not used it as it doesn't stand up to gasoline.
The reason I bought a rebuilt carb from Cowboy John was because I believed the carb was losing gas. It would not start after 2 days of not driving it. I knew his rebuilt carb would be better than me rebuilding my old worn carb.
Old Nov 20, 2021 | 11:54 AM
abe's Avatar
abe
I put gas in the bowl Thursday evening. I filled it to where the bowl gets wider. Here's what it looked like at noon today, Saturday. Most of the gas has drained out. So this winter I'll rebuild it and keep it as a spare since on the truck now is a rebuilt carb I bought from Cowboy John.
Old Nov 20, 2021 | 04:33 PM
Bob Ingram's Avatar
Bob Ingram
That’s exactly what my carb did, leaked right down to the top of the power valve. I bought a PV from Charlie at vintage speed, no more leaky PV.
Old Nov 20, 2021 | 05:55 PM
abe's Avatar
abe
I suppose I'll be getting more mpg now!
Old Nov 20, 2021 | 08:13 PM
Harrier's Avatar
Harrier
I need to pull my carb this winter....when I get a workbench in my shop.... and try this. I think I have a similar problem.
Old Nov 21, 2021 | 09:45 AM
Bob Ingram's Avatar
Bob Ingram
A local mechanic told me to use ATF to test for leaks. It’s easier to see the red ATF than almost clear gas.
Bumblebeast
1978 - 1996 Big Bronco
Oct 5, 2019 09:25 AM
greenmachine55
May 25, 2015 08:09 AM
69taposer
Jun 23, 2012 05:31 AM
lordoflivernois
Dec 10, 2007 02:20 PM
jds1971
Sep 18, 2002 05:39 PM
