Np273 electric issue
Old Nov 16, 2021 | 09:16 PM
Grody46's Avatar
Grody46
4wd Low
So I’ve got a 06 6.0 and the solenoid to switch to 4x4 4lo makes the typical electrical/mechanical click but never actually engages no noise or rattle trying to drive with it set to 4x4 but it’s not actually engaged, anyone else have similar problems? I’m going to pull the solenoid tomorrow to see, but figured I’d ask if anyone had similar problems. I can drive a few blocks check driveshaft and it’ll spin have also locked diffs on jacks and tested spinning shaft to ensure they’re operating also tried engaging 4x4 and spinning shaft, 4low engages low speed but no front wheel engagement.
Old Nov 17, 2021 | 07:47 AM
xcrsp440's Avatar
xcrsp440
Check for codes. They will be set if the solenoids are not working.
If you manually lock the hubs, do you have 4wd?
Fat Diesel
Dec 24, 2012 08:14 PM
wbhess
Nov 29, 2010 11:15 AM
spudgunman
Jan 24, 2010 07:10 PM
lucas000
1983 - 2012 Ranger & B-Series
Aug 25, 2006 12:36 PM
TheSequil
Apr 12, 2004 03:57 PM
