Tilt hood kits
Old Mar 7, 2025 | 05:34 AM
Marten's Avatar
Marten
I agree with John here. I used the SW-68 after my brake line switch did not work.
Not sure why you need to drill out spot welds for the tilt hood, I did not have to do that. just a little cutting on the front of the hood.
For the hinges, if you are scraping them, take a grinder to the bolts.
Old Mar 7, 2025 | 08:08 AM
Swank56's Avatar
Swank56
Brake lite sw
https://www.ebay.com/itm/39217460901...mis&media=COPY
I’m using this one and haven’t had any problems. I did have to make a bracket to mount it.
I’m using a fire wall mount master cylinder
Old Mar 7, 2025 | 08:52 AM
56panelford's Avatar
56panelford
The spot welds he's mentioning would be the ones for the brackets originally securing the support rods under the hood.
the track that holds the rubber radiator seal needs to be trimmed back and those brackets removed to install the kit.
Old Mar 7, 2025 | 01:44 PM
ajsunnyB's Avatar
ajsunnyB
the spot welds I am talking about are where the three .hold brackets are at. I just may smoothe them.out and drill them.holes. that area is a little flimsy. This morning those two nuts on the right hood hindge finall came off. I oun a 1978 Harley FLH 75th anniversary. And ya your right about the brakelite switch looks the same maybe a little larger around with set screws instead of those Ford round clips. That's great I I will order from Dennis kirk. Get several parts for my Harley their. Thank.you.for your post. Think I.will get on U tube and review the measurements for the hood on drilling the three holes.
Old Mar 7, 2025 | 02:00 PM
ajsunnyB's Avatar
ajsunnyB
Not sure if you have a hanging brake pedal or the original through the floor but here are some to choose from..as far as the spot welds you could try prying up a little and the welds may become more evident..
https://www.ronfrancis.com/category/brake-switches
I'd stay away from any pressure switches though, stick to the electric ones
hi 56panel ya I tried that moving the rod up and down but still.no spot welds. I cut off the 90 degree flange and smoothed the metal. With a grinder, think I will position the new flip brackets and just drill the holes and shave a little off the rubber radiator..I did get the half inch nuts off the old hood bracket. So that's done. Oh I am making progress. Little at a time. Another post suggested I try a Harley Davidson brake pressure switch. I own a Harley 1978 75th anniversary ,FLH looks the same larger round and used screws instead of the clips. Better idea. Thanks my Brother from that 56 Panel.I would love to.send photos taken many off my phone but still cannot post.AJ
Old Mar 7, 2025 | 04:28 PM
This is my rifle's Avatar
This is my rifle
Nice truck and wheels also 👍 what size rims are they and what size tyres do you have fitted ? I have seen a set of these on eBay that I would like to buy for my 1951 f1 but, I haven’t got a clue about what size rims that I should be looking for. Thanks
Old Mar 8, 2025 | 04:03 PM
56panelford
F-100 Tilt Hood This is the PDF from CCP
Old Mar 9, 2025 | 10:12 AM
ajsunnyB's Avatar
ajsunnyB
looks like you posted about another post. Some how it ended up on this tilt hood. My wheels are Chrome rims 15 inch by 9 inch in front. And 15 inch by 14 inch on my rear. Dont run radials. Only Bios ply. My 1955 F-100. If that helps. Kinda placed my tilt hood on hold. Decided my measurements from the hood center must be exact. For my hood to fit properly. Once you install the flip rods on the hood. There is no way to adjust them. When I removed the old prop rods that hood popped. It's warped. Or a bit twisted. I've got to rethink thus. Short of buying a new hood. AJ
Old Mar 9, 2025 | 10:27 AM
ajsunnyB's Avatar
ajsunnyB
forgot to mention the left side spot welds were very defineable. But off the edge and one weld centered. That one is easily removeable, just about decited just to leave those plates their..that area is a little flimsy. Still concerned about hood warp!.AJ
Old Mar 9, 2025 | 01:59 PM
ajsunnyB's Avatar
ajsunnyB
Well I was looking at my hood rods, one is tighten up all the way and the right side was way different. You can see the slight warp if you lay the hood flat on my concrete. It comes up about 3/4 inch on the left side at the front.from touching the floor. I don’t know how flat my concrete floor is, my building was built in 1990.3/4 inch That’s not much, I wish I could have had some kind of adjustment, with this CCP rods they use on the hood. Moving that hood rod around could effect the open and closing. My old Ford hood hinges were probably originals and I could never get it to close. Especially in the rear.AJ
Old Mar 11, 2025 | 04:39 PM
ajsunnyB's Avatar
ajsunnyB
Well today I managed to get a little assembly done on my tilt hood, it’s got a warp of about 3/4 of an inch. On the left side used four sand bags to weight down the warp it lays flat and I plan to adjust the hood rail thru drilling it out.also the fittings that attach to the hood rails are to large so I used washers to clean that up. This is going to work out, so I will start the engine side in a few days. Installing the hinge plates and the rail. AJ
Old Mar 12, 2025 | 09:02 AM
ajsunnyB's Avatar
ajsunnyB
Well I kinda realize the way the hood is set up determines the way it will fit on your truck. I decited to measure from the center line to the bracket must be Zero zero to fit into the truck and lock down to the original hood latch! I completed all the paint on the steel parts instead of black I used silver high temp Now it’s getting close to my Back Surgery several doctor visits on my schedule and up to six months recovery and rehab. It’s going to be a long process, and I think it will give me a few more years of life. AJ
orcas tow
18
May 2, 2026 05:24 AM
bug-e-dude
Mar 16, 2017 04:47 PM
bighalt56
Mar 20, 2011 06:18 PM
Franklin2
Dec 24, 2001 03:43 AM
clizer
Offroad & 4x4
Mar 5, 2001 04:01 PM
