302 to 351
Old Nov 13, 2021 | 11:59 PM
Spencerm34's Avatar
Spencerm34
302 to 351
So I have a 1990 f 150 with a 302 that needs a head gasket but I also have a parts truck it's a 1996 f 250 with a 351 with a bad trans really would like to just swap the 351 into it. Questions are can the 351 mount to motor mounts in the 1990 with the 302. And will the computer for the trans on the 351 work right with 302 one.
Old Nov 14, 2021 | 04:02 AM
My4Fordtrucks's Avatar
My4Fordtrucks
It is almost a direct swap. If it is reusable, you will need the Y pipe from the 96 because the 351 is slightly wider and taller than the 302. Do not use any of the wiring harness or computer from the ‘96.
Old Nov 14, 2021 | 11:57 AM
Spencerm34's Avatar
Spencerm34
What about fly wheel and so all wiring from 302 will work with 351
Old Nov 14, 2021 | 12:00 PM
SFaulken's Avatar
SFaulken
No, you'll need the 351W Flywheel. The 302 Flywheel will not be balanced correctly.
Old Nov 14, 2021 | 12:36 PM
Conanski's Avatar
Conanski
You need a flywheel or flexplate that match the engine balance(28oz) and is compatible with your trans. What trans does the truck have?
Almost. You will need to source an early 5.8 distributor that carries the TFI module on the side.
BAKAFLAKA
Engine Swaps
Oct 13, 2015 12:12 PM
olekingkroll
Jul 2, 2009 10:33 PM
ganey2006
Dec 21, 2006 06:37 AM
javi2001
Sep 20, 2004 04:38 PM
thejerold
Aug 25, 2003 09:27 PM
