Drum Brake issues
Old Nov 13, 2021 | 08:34 AM
KOT390's Avatar
KOT390
Drum Brake issues
1970 F100, 390 3sp. 2w/d. 4 wheel drums
Brakes have been completely rebuilt. Everything new. Turned drums before installing. The issue is that the brakes work perfectly when the brakes are still cold/cool. But when they warm up and get hot they start pulsating and pulling to the right. I just don't understand this change or what to do first. Obviously the heat expands the materials, but to this extreme?? There's a long backstory to the brakes as it is, I've played hell with these things for awhile now and I'm out of ideas. Thanks
Old Nov 13, 2021 | 10:40 AM
jzjames's Avatar
jzjames
With new shoes it does take time for them to seat/set in to the drums.
if they are currently grabbing/pulsing when hot I would play with the adjusters for a while and see if it gets better over time.
Old Nov 13, 2021 | 03:54 PM
thechief66's Avatar
thechief66
Could be a bad drum. If the drum is worn too thin it can warp with heat.
Old Nov 13, 2021 | 07:39 PM
KOT390's Avatar
KOT390
They are new drums...turned before installation. I will probably try to adjust them a bit. Thanks
Old Nov 15, 2021 | 08:59 AM
NJBone's Avatar
NJBone
Make sure to use the auto adjusters a bit too if you haven't already.
Old Nov 17, 2021 | 09:31 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The auto adjusters only work (if they work at all!), when you back up and step on the brake pedal.
Grizzly93
Large Truck
13
Jan 4, 2015 05:50 PM
fastfew
39
Aug 7, 2008 04:02 PM
Coop65
May 2, 2006 09:40 AM
sharkdance
Mar 15, 2005 09:23 PM
41Clay
1947 and Older Ford Trucks
Nov 4, 2002 03:04 PM
