6.9 IDI Engine Harness
Old Nov 9, 2021 | 11:52 AM
GrantV's Avatar
GrantV
The engine wiring harness on my 1985 6.9idi is completely warn out. The wires have been splice and tangled all over the place. I would like to replace everything, but cant find a proper diagram for it.
Things I need to know:
Is the injector pump the only thing I need to give power to for it to run, and what kind of fuse should I use for it?
How do I wire the 60 amp alternator and voltage regulator?
Any help is appreciated. Thanks.
Old Nov 9, 2021 | 04:50 PM
Franklin2's Avatar
Franklin2
Here's some of your wiring. The fuel injection pump is on the right upper side of the diagram called "fuel shut-off solenoid". It's all fed from the blue fuse link V in the center.
Old Nov 9, 2021 | 04:52 PM
Franklin2's Avatar
Franklin2
Here is where fusible link V is fed off the ignition switch. Left side of the diagram below.
Old Nov 9, 2021 | 04:57 PM
Franklin2's Avatar
Franklin2
All your diagrams are here. https://www.garysgaragemahal.com/1985-evtm.html
If you look down the list, you will see pages 23-26 are diesel, as well as 47 thru 51 and a few others.
Look at the top diagram in my first reply. Look at fusible link V. Below it, it says "page 24". That tells you where it comes from. The second reply that has the ignition switch is page 24 and it shows fusible link V. If you look below that fusible link picture with the ignition switch, it says "page 47". Page 47 is the diagram in my first reply.
OBD_F350
Apr 28, 2020 06:47 PM
Grandpa's66
May 15, 2018 03:24 AM
tfarris
Jan 16, 2015 08:38 PM
blick
Nov 10, 2014 01:50 PM
idahoFORD350
Mar 31, 2013 09:04 PM
