Cold Start Rattle
Old Nov 9, 2021 | 09:31 PM
dolvio's Avatar
dolvio
Originally Posted by JKBrad
Not necessarily, they would have full oil pressure going to them. But when the computer tell the phasers to move, they would give a quick rattle for 2 seconds or so. If it was the timing chains the noise would always be present. I asked about opening the hood because you are likely to hear the sound differently that way. Now you say you hear it at the wheel well, but once the hood is open you will likely hear it coming from the top of the engine.
So I opened the hood and can very easily hear the sound on top of the engine or maybe
pre specifically the left side. Hard to tell. It sounds like someone is dragging a piece of chain behind them on concrete. What do you think?
Old Nov 9, 2021 | 11:04 PM
JKBrad's Avatar
JKBrad
Sounds more like the timing chains based on your description. The left cam phaser may be bad too.
If it’s still under warranty, take it to your local Ford dealer. If it’s no longer in warranty, do a web search for a local independent shop with the highest customer service ratings.
Old Nov 9, 2021 | 11:14 PM
dolvio's Avatar
dolvio
okay thanks for your help. I still think it could be the wastegates. I’ll see what ford says soon. Thanks!
Old Nov 9, 2021 | 11:32 PM
JKBrad's Avatar
JKBrad
It could be. It’s really hard to tell by listening to the video. But I have not seen any issues with turbos posted other than with connections. How many miles on it?
Old Nov 9, 2021 | 11:34 PM
dolvio's Avatar
dolvio
60k and otherwise drives like a dream. Zero noise after the initial start.
Old Nov 10, 2021 | 11:21 AM
dolvio's Avatar
dolvio
seems like it’s probably the driver side wastegate linkage. I could see it rattling this morning. I pinched the passenger side with no luck but will try to do the same on the driver side.
what’s the fix for this? New turbo?
Old Nov 10, 2021 | 04:01 PM
JKBrad's Avatar
JKBrad
I was just doing some research and stumbled on this. Worth looking into.
Old Nov 12, 2021 | 08:30 PM
Papa Tiger's Avatar
Papa Tiger
All motors have some rattling when cold started at/near/below 0 degrees C. Warm it up, shut it off. let it set 10 minutes and restart it. Listen to see if you got the rattle back. If not your are good. If so you probably got front timing chain problems, most likely adjusters. Timing chain adjusters do break but usually that creates severe front engine noises. Check for codes. If you got timing chain problems you most likely have a code. Say a rich idle on one bank ! If you do have a code, resetting it may remove the situation entirely.
SuperDutyScaler
Apr 10, 2021 07:32 AM
Dan V
Feb 2, 2020 09:55 PM
T diesel
6.2L V8
45
Jan 9, 2017 05:11 PM
97_Stroke
Mar 2, 2013 09:50 PM
